My toshiba regza 32 inch has audio but picture will not stay up. It will come on when turned on and then go black. it is two years ago
    Genius:
  • 2,920 Answers
You need to take it in for repairs.sounds like the motherboard is going bad on it or possibly the power supply
Posted on Aug 17, 2008
Regza intermittantly blacks out. Can be when it
Repaired a Toshiba 32hl67 by reseating the connectors on every board and cutting the wire tie on the back of the screen. I know it sounds crazy but I think the wire tie is what did it. I think it put enough pressure on the wires to cause just enough disruption in the currant flow to make the control board think something was really wrong and it shut down the screen as a safety measure. What every the case the TV work flawlessly now.
Feb 21, 2010 | Toshiba 32HL67 32 in. LCD Television
I have a 32 " 1080 PI LCD Regza. Have audio but no picture. Menu items come up on screen, but no input from Sat. Box, Xbox etc..
check your power supply. and check your
invert board back lamp driver if you have a
miltmenter check your vote at the invert board.
if you do have the rigth volt yiu have a bad invert board.
Aug 10, 2009 | Toshiba REGZA 47HL167 TV
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 04, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Vertical line on my 46" toshiba lcd tv
The only logical solution for the problems people are having for the toshiba regza's tv's is to get into a class action law suite..., they contiue to sell tv's with defective parts and refuse to help the customer that spent large cash to find out they last if your lucky 2.5 years, they are junk and anyone with one will soon find out./.......
Apr 03, 2009 | Toshiba Regza 46RV525U 46 in. LCD HDTV
Toshiba Regza screen is black but audio works
I unplugged everything and then reset-up the tv, dvd player, audio, and other components.
Dec 29, 2008 | Televison & Video
Poor picture quality on Toshiba Regza 32AV555DB LCD TV
i had the same problem! i just changed my scart leads to some quality gold ones, this made the picture a lot crisper . hope this helps :0)
Dec 14, 2008 | Toshiba REGZA 32WLG66 32 in. Television
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
