Question about Whirlpool Washing Machines
My 2004 Whirlpool LSQ 9549 PW Washer is producing an electrical overheating smell when it is on. I smells like someone is smoking in the laundry room and no one here smokes. Any ideas.
2 Suggested Answers
SOURCE: Burning Smell - smoking coming out of it
I believe we tracked it down to the pressure switch mounted on the drain pump. The device had a strong electrical burn smell and is positioned where it could easily have smoked the basket. We're putting the washer back into service and if I have a recurrence I will post the information. BTW ... Replacement was simple and the part was $26 including shipping.
Posted on Jul 22, 2008
My calypsal washer smells like burning electrica or rubber in the spi mode
The motor could be leaking oil. Pull the machine out and look for stains or puddles on the floor.
Oct 07, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
Smells like burning electrical
Its sounds to me like maybe the belt is slipping that will smell like something burning.
Smells musty and makes laundry smell musty
Sears technician recommended not using liquid detergent. A week or so after we switched to powder the smell went away.
Jan 08, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Burning smell
There's a number of reasons to smell burning after a washing machine cycle. It's a 220V appliance, so if it short's out it will cause problems. It's more likely the motor being overloaded making it hot and causing the electrical burning smell, or a short that's overheating something electrical. Check to see if the belt that spins the whole barrel is melted or worn anywhere. Inspect the wiring that's attached to the system that engages spin, which is different from agitation by the big tower.
If these both check out, an trip to the Maytag Man might have to fix overloading motors or relays, or switches, if anything turns up in your search for the source of the electrical smoke. Ozone is what you are smelling, FYI.
May 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
The smell of my laundry
Try putting one more sheet in the dryer as far as the Tide with Downey it`s propbably getting rinsed out when your washer goes through the rinse cycle.
Feb 20, 2010 | Whirlpool Dryers
Washer stopped working
If after waiting for a while it still does not respond - most likely the motor is burnt - especially if those were all very heavy loads
Regards
Sep 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool duet front loader washer
Mold and bacteria in your door seal is a symptom of problems deeper inside the unit. All washers - not just Whirlpool, have this problem. The area of worst buildup is always on the inside of the plastic outer tub just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this problem area add 1 or 2 caps of smelly washer cleaner to a full load of laundry. The added bulk of the laundry will raise the water level to include the "splash area". Intermittently pause to soak more extreme cases.
Aug 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Jul 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
Washing Machines Logo
67 people viewed this question
Dan Webster
Dan Webster
Sal De
