Got 54.18 error on HP 2605dn ... Black toner empty. All others were very low as well. Refilled cartridges, reinstalled all four. Getting very faded image when printing test page from properties window.
  • 55 Answers
SOURCE: HP psc1210 not printing in Black
u better try this ,remove color catridge from the printer,switchoff n switch it again with black catridge only,the printer will give catridge error dont worry ,n try to print any black font document from the printer n see does it print black,n reply
Posted on Jan 28, 2008
  • 41 Answers
SOURCE: missing 3 mm of print from top to bottom
try goign to print settings, and there you can change the setting for margins and headers and footers.
Posted on May 13, 2008
SOURCE: Magicolor 2400W print fades on right side of page
Have you tried cleaning the leans at the bottom of the printer? Open the cover, pull out the drum. Under it is a long, narrow piece of glass. If it gets dusty or toner accumulates on it, it will cause streaks in the printing. If this is dirty, take a clean, soft cloth and very gently wipe it off.
Posted on Jun 01, 2008
  • 30 Answers
SOURCE: black printing faded although toner not low
The black developer is defect, you have to call the service to solve this problem. and install FW Update V1.29.12.35
Posted on May 28, 2009
  • 392 Answers
SOURCE: ML1640 not working after toner refilling
Download the firmware from here
run the software and this will reset the page count to 0. Samsung printers generally do not support a refilled cartridge and thus the red light.But resetting the page count to 0 makes the printer detect the cartridge as an intoductory one.
Posted on Sep 01, 2009
HP1022N laserjet printer there are black specs along the printed page. looks like toner smudges.
toner specs are usually caused by a bad cartridge. If it is a refill, it is possible that the waste toner bin was not emptied when cartridge was refilled. Try different cartridge as your first trouble shooting step.
Jul 22, 2011 | HP LaserJet 1022 Printer
I repaced the magenta cart. because it was empty, but now I am not getting red. What do I do?
Shake the cartridge to loosen the toner. They may have clumped-up during storage.
Nov 23, 2010 | HP LaserJet 2605dn Printer
How to solve CRU Fuse error ?
Check the TONER Cartridge and Reinstall it
CRU Fuse Error
Means : The toner cartridge is not installed correctly
You can set the machine to ignore the “[Toner Empty]”
message and to continue printing incoming faxes.
Ignoring the Toner Empty Message
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button < or > until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button < or > to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Jan 21, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
COF36 error on a Bizhub C350
C0F36 error means abnormally low toner density detected Black ATDC Sensor. Check for the black toner and try reinstalling the cartridge if replaced already. And if the toner crtridges are empty then replace the cartridge.
Please do rate this solution as FixYa and revert for further assistance.
Apr 21, 2009 | Konica Minolta Office Equipment & Supplies
Merroy error 100.10.10
There isn't a known error of 100.10.10 on an HP2600n. The is an extremely rare 101.000 which is color plane registration but I'm guessing your not getting that.
I'm assuming your actually having one of the following:
10.0000, 10.0001, 10.0002, or 10.0003
10.1000, 10.1001, 10.1002, or 10.1003
These are supply errors (toner cartridge). The toner cartridges have a smart chip on them and if it's not reading correctly you can get one of the errors I mentioned above in the "10" errors. In that case look at the last number in the string to isolate it. "0"=Black, "1"'Cyan, "2" =Magenta, "3" = Yellow. Simply replace the identified cartridge.
We have seen a lot of refilled or self refilled cartridges that the supplier or user didn't put a new smart replacement chip on the cartridge, pulled the chip without replacing or actually put the wrong one on the cartridge. This would cause the "10" errors. In some rare cases a surge in power can knock out a chip on the cartridge.
Here's a photo of the chip on the black cartridge to help you locate it.
If you are getting a "10" error identify the last number to identify the color and replace the cartridge.
If you are ACTUALLY GETTING AN ERROR 100.10.10, contact HP as it is an undocumented error and likely only HP may be able to resolve it. I have even researched the error through Canon (they make they base machine for HP) and Canon has no record of this error either.
I hope this helps you. If so hit it with a FIXYA. Thanks.
Aug 28, 2008 | HP Color LaserJet 2600n Printer
HL-4040CN don't show or read new refilled magenta cartridge.
If you have removed and reinstalled the magenta cartridge several times, it is very likely the cartridge is defective out of the box. If you have another magenta cartridge, put that one in and see if the problem resolves. I'm betting it will. If that second cartridge does work, then return the defective cartridge to where you purchased it - they should replace it without a hassle.
May 10, 2008 | Brother HL 1440 Laser Printer
Remove and check colour cartridge HP 23, HpPSC500 error
Did you trying cleaning the cartridge contacts on your machine?
Jun 23, 2007 | HP PSC 500 All-In-One Printer
532 people viewed this question
