Question about Airlink (AWLH4130) 802.11g/b Wireless Adapter
No WEP capabilities...
For some reason, my AWLH4130 will connect to networks which have no WEP just fine, but if I try to connect to any network secured with WEP, it can't connect, and doesn't give me any reason why. I'm sure all the configuration is correct, because I have a laptop connected to the network. Any ideas? Thanks in advance.
  • hockey27kid Sep 03, 2008
    I am in the same situation as some of the other comments I have seen. I am able to locate and input the encryption key to my local wireless network. It shows that it is connecting to the network but in the end it never truly does connect. I erase the profile and try it again with the airlink radio as well as the windows wireless and it is the same thing. Nothing happens. Just give it the priority message but wont connect. Any solutions?
    Problem Solver:
  • 5 Answers
WEP encryption is not very safe and will be less in use in the future. Anyway, you have to determine, if WEP 64 bit or WEP 128 bit is used (26 digits), mostly it is set to 128 bit.
If the connection fails, try to input the key with WZC (Windows Zero Configuration) instead via the interface-software from the manufacturer. If the service WZC is started (important!), you have a tab in the properties of the adapter to make the configuration with conf.less win connection, you only have to put in the right key.
Gr
Phalanx41+
Posted on Aug 18, 2008
Enable wireless capability
Certain models of Acer desktop computers are designed with wireless capabilities.
These capabilities can be added to an Acer desktop system that does not connect wirelessly with either an internal or external wireless card, depending on the computer's configuration.
When the wireless connection is not working properly, you can troubleshoot the issue yourself.
The troubleshooting process eliminates the problems that may be preventing the Acer desktop computer from connecting wirelessly.
Check to see if any other computers at the same location are able to connect wirelessly.
The issue may reside with the wireless router or access point.
Power cycling the router or access point may resolve this issue.
Verify that the wireless adapter is enabled.
Click the "Start" button, then "Control Panel."
Click "Network and Sharing Center," then "Change Adapter Settings."
If the wireless adapter is disabled, right-click on it and select "Enable."
Connect to the proper wireless network.
The Acer may be attempting to the connect to the wrong wireless network, or it may have lost its connection to the correct network.
Click the wireless network icon in the task bar.
Click the proper wireless network, then click "Connect."
Enter the network password (or WEP key) if prompted.
May 26, 2013 | Acer Aspire Computers & Internet
Can't Reconnect to Secure Wireless Network
there is a problem with your WEP key, means the password which is used to enter your router or network. simply delete the network from the network list and connect to the network again and insert the correct shared key.
May 03, 2010 | 2wire 2700HG-B Router (2700HGB)
Where is the wep key located on my virgin router
Connect your desktop computer to your Belkin router, and access the router's built-in web-server software. Then, run the "Wireless Network Setup Wizard", to configure the router's wireless networking capabilities. As part of that process, you will be required to _create_ a "WEP-key" value. Use that value when configuring the wireless capability of your PS3.
Jan 24, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Kodak EasyShare W820 - Wireless network problems
This is supported by your provider not KODAK.
Pls. contact your internet provider
Sep 18, 2009 | Kodak Cameras
What is a ssid and a wep key. I am dumb.
SSID is the wireless networks name you want to access.
WEP is a special hexadecimal key to secure your network means if you want to connect a wireless network you will have to put this key.
It will be provided by the admin
Aug 12, 2009 | Office Equipment & Supplies
My itouch won't connect to my wireless network
This happened to me as well. Turned out the iPod touch doesn't support WEP encryption properly, and sometimes can't log onto those networks.
If your network is WEP-encrypted, try changing it to WPA.
Aug 02, 2009 | Apple iPod touch
Pc doesnt connect wirelessy but liks with hard wire
It is a clear cut issue of security but dont worry
First of all the wep key is a 10 digit no if 64 bit wep or 26 bits if it is 128 bit wep.
You have to enter the numbers not any passphrase that you entered in your router
Now I assume that you know how to go to the router set up page by entering your default gateway address in the address bar.
Now change the channell to 6 or 11 which will give you the best signal strenght .
Now the main reason it is not connecting is because you have not deleated the preffered networks.
So the network name identified by your computer dosent have a network key so it misinterprets and cannot detect and also after setting security signal drops so changeing channell is very important.
On your wireless PC go to wireless network connections -- properties -- deleate the preffered networks ----- press ok---- Refresh network list ---- click your network ---click connect ---- enter security key (numbers please) ---- connect .
For your e71 do the same .deleate preffered networks and reconnect .
This should help and if there is any problem do let me know .
Mar 17, 2009 | NetGear DG834G Router
Connects to Access Point but the internet cannot be found
The main reason why you have this error message because your computer is not getting a valid IP address from teh wireless network, and the reason why its not getting a valid IP address is the wireless security or sometimes called WEP/WPA kay are not type in to the correct place, If you have a WEP enable on your wireless network you will have two option on the Linksys WLAN monitor where you can type in teh security key, you will see two boxes there when you try to connect to the secured network one says Passohrase and one says WEP key1 and if yuo have a wireless key that has a total of 10 or 26 key character you need to type that on the WEP key1 box leave the passphrase blank...But if it still didn't work you can contact this number for help 1-877-787-8749....
Oct 15, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
New HP laptop will not connect to wireless secure network
Problem solved. I disabled the security on my network. I connected the new laptop to the unsecure network. I saved the settings on the laptop for the unsecure network. I rebooted the laptop. I re-enabled security on the router. I tried to connect to the network. I got an error on the laptop saying the network saved settings did not match. I modified the settings to a secure network on the laptop and saved the 128 bit key. Rebooted everything. All works fine now.
Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Cannot connect to network with WEP key encryption
It will not connect to a wireless network with WEP. it supports only the latest encryption. Try changing the encreption on your router to WPA or WPA2
Mar 17, 2008 | Archos 605 Digital Media Player
Airlink (AWLH4130) 802.11g/b Wireless Adapter Logo
97 people viewed this question
Top Airlink Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you an Airlink Computer and Internet Expert? Answer questions, earn points and help others
