Question about Whirlpool LSR6232J Top Load Washer
My Whirlpool LSR6232J serial 4217141
Hello..the washer stated above doesn't spin..It fills up with water but when its time to spin...It makes a loud sound of like clicking..I also tried opening and closing my lid for the clicking sound and the sound is there..It was working fine today but when I put in three constant loads..It went to this state..Any help would be appreciated...Hope to hear from you soon.
  • 5,911 Answers
If the washer fills, but fails to agitate or spin, the likely cause is a failed motor coupling. There is usually a loud rattling noise associated with a broken coupler. This may be the noise you hear. NOTE: The washer will STILL drain if the motor coupling is bad. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
If the washer fills, may or may not agitate, then stops right after filling, or just before the spin cycle*, you more than likely have a failed lid switch. NOTE: The washer will NOT drain with a defective lid switch. The following link explains how to replace a lid switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
* These symptoms vary between models. The result is still the same, however, the washer generally stops at some point before the spin cycle and will not complete a wash load.
Read through both links and try to determine your symptoms. When it comes to lid switches, they sometimes come loose and only need to be retightened. Double check the mounting screws. In most cases, the clicking sound of the switch indicates the switch is good. However, I have found where the actual switch assembly was cracked or separated and made a similar sound, but the contacts were not engaging. Inspect the entire switch, if in doubt.
Motor Couplers allow for the Drive Motor to drive the transmission. This is the connecting link between the two. The coupler takes the punishment in order to protect the motor and transmission from damage. If you are in the habit of washing heavy loads (i.e., blankets, comforters, etc.) this can reduce the life of the coupler. A tell tale sign of a broken coupler is a pile of black filings under the washer. This is usually particles of the rubber bushing between the coupler halves. Another thing that happens is the center hole of the plastic coupler would round out and spin on the either motor or transmission shaft as the older couplers were made entirely of plastic. Replacement couplers (the part number I provided in the link) now have a steel grommet in the center of the plastic which prevents this from happening.
If you check both these possibilites and you still have problems, let me know. I'm trying to rule out the possibility of something more significant, like a transmission problem. Both of these parts are inexpensive (about $50 combined) and can be found at searspartsdirect.com. Just type in your model number in the search menu. The lid switch is located under the "Top and Cabinet" heading as item number 11 (part number 3949247). The Motor Coupling can be located under the "Brake/Clutch/Gearcase/Motor/Pump" heading as item number 13 (part number provided in the link). For comparative shopping, repairclinic.com also carries these parts, sometimes at a reduced price.
I hope this helps you. If you have questions, please let me know.
Posted on Aug 18, 2008
SOURCE:
Whirlpool duet washer fills with water (maybe overfills) then stops and the wash light flashes an 8 then 1 type sequence
Hello, we are sorry to hear that you are experiencing this problem. We would recommend having a certified technician out to take a look at the Washer and give the appliance a proper diagnosis. If you would like further assistance you can send your name, phone number, address, model/serial number and the date of which you purchased the Washer to [email protected]
Apr 18, 2017 | Whirlpool duet Washing Machines
The washer will not drain. It goes through all the cycles, fills with water, washes, but when it gets to any of the spin cycles, it stops. The hose going to the drain is NOT clogged.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 04, 2011 | Whirlpool LSR6232J Top Load Washer
Whirlpool washer #LSQ9244EQO, serial # CG5041659 does not work. After filling with water it just makes a loud grinding noise when it goes to spin. Its 12 yrs old, is it worth it to fix?
Hi, you probably have a broken coupler between the motor and transmission. The piece is about 20$ and can be replaced easily depending on your repair skills!!
Part number 285753A
Jun 21, 2011 | Washing Machines
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Washer made a loud noise after it filled up
The washer machine tried to spin but the bearings (or other mechanical part) broke. This is a serious issue that needs a technician for repairs.
Sep 07, 2009 | Whirlpool Washing Machines
Whirlpool Stylemaster 4217141 tub not moving wash/spin cycles
Sounds like the drive belt is broken or very loose. Take off the back and check the belt. If loose or missing, tighten or replace. This is usually done by loosening the motor support bolts and moving the motor until the belt is tight, then re-tighten the bolts. Replace belt in the same way.
Apr 22, 2009 | Whirlpool Washing Machines
Spinning doesn't take place during spin cycle
One possible problem is the door interlock switch. This switch prevents spinning when the door/lid is open. If the switch is bad (open/off all the time) it sends a false signal that the door is open and washer will not spin.
Does the machine just sit there when it's not spinning or does it sound like it's trying to spin but can't?
Apr 21, 2009 | Washing Machines
Whirlpool agitator not working!
Hello Roger.
Please do the following checks for they might just help.
Check that the water supply valves are turned on
Inspect the filter screens
Test for overheating
Inspect the water pump
Test the water inlet valve
Test the motor
Most probably this case may be due to a faulty motor.Good luck.
Jan 09, 2009 | Whirlpool LSR6232J Top Load Washer
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Will not let water come into washer.
not a good model number but anyway the water inlet valve needs to be replaced
Apr 16, 2008 | Whirlpool LSR6232J Top Load Washer
Whirlpool LSR6232J Top Load Washer Logo
342 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
