Question about Fantom Vacums XT450K Upright Vacuum
No wand suction
I have cleaned out everything and it still whistles and I have no suction in the wand.
  • Anonymous Nov 04, 2008
    whistles - no suction
  • cindyb99207 Mar 14, 2009
    I vacuumed up a lot of loose material, and after that cleaned out the trap, took off ther front and cleaned out the area around the brush, belt, air intake, and still no suction on the hose. I can't really tell if it is sucking in the brush area. Where do I even take it for service?
  1. i cleaned out my fanton and no suction in wand and still whistles
Posted on Oct 11, 2008
    Problem Solver:
  • 4 Answers
Make sure the "colunn" portion of the vacumn is in clicked into the upright position, make sure the power button is clicked to the correct direction (left or right of center). I had to keep playing with diffferent settings to get better suction in the wand. I think this vacumn sucks (pardon the pun) it's a POS!
Posted on Jun 29, 2009
The wand on this vacuum has suction, but the base unit does not. I have checked all filters, the hose and connections for blockage, etc. The brush is rolling.
some vac's have a small slide that stops te wand suction when the wand sucks the other parts gets none
May 11, 2015 | Vacuums
Hoover s3765
There may still be a clog or restriction somewhere. If the hose. Has good suction the problem may be. In the wand and floor tool.
Mar 21, 2014 | Vacuums
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction when using wand on electrolux precision upright
There is a ball valve between the wand hose and the base hose. It can get stuck in the "base" mode, which won't then redirect suction to the wand hose. There is a spring under the cup that the open end of the hose rests in. When you release the wand from the holster with the one-touch quick release, that spring pushes the cup up and turns the ball valve to the wand setting.
  1. Unplug the vacuum.
  2. Using the one-touch quick release, remove the wand from the holster.
  3. Verify that the wand "cup" is indeed in the higher position. Do this by pushing on the bottom of the cup with your finger. It should easily depress.
  4. Remove the wand hose from the main unit using the quick disconnect feature. Put your fingers into the hole and feel to the right. You will feel the closed valve, verifying that it is stuck in "base" mode.
  5. Using a screw driver, insert the tip at the TOP of this valve and gently pry it downward. This shouldn't take much force.
  6. Reassemble the hose wand using the quick connect feature and reholster the wand.
  7. Plug in the unit and verify that the base unit has suction.
  8. Remove the wand from the holster and verify IT has suction.
Jul 27, 2013 | Electrolux EL8807A Precision BrushRoll...
Hi my dyson dc18 has great suction from wand but when you got to use the vac for floors little suction but wand still got suction even while vacuming floors is it suposed to stop suction from wand
My Dyson dc18 had the same symptoms. The wand worked well and the floor bar had no suction. After removing pieces & shoving my fingers into the machine (no blockage) I found the suction pipe rotates between two positions (floor and wand). It looks like a piece of plastic broke on the outside housing, so it no longer rotates positions when the wheels are raised or lowered. My son found we can move the suction by sliding a finger into the mechanism behind the wheel cover, and rotating the plastic piece clock-wise or counter clock-wise until it locks into position. It's a big pain but it works for now. I wish I could find a replacement piece online. Patty
Apr 03, 2010 | Dyson DC18 all floors Bagless Upright...
No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson hose looses suction
You have a blockage in the wand. Stand behind the machine and:
1) Remove the u-bend which is located NEXT to the right-hand side wheel, NOT above it. It connects from the bottom of the long gray hose to next to the right-hand side wheel. It is attached to the machine with a rectangular-shaped clip - push the clip and pull the pipe down.
2) Look through the wand if you can (DC07 wand is bent) - if you can't see the ground you have a blockage in either the hose or the wand
3) Remove the hose and separate it from the wand - hold the wand up into the air and look through it - if you can't see light coming through the other end, there is a blockage in the wand. Use a long object like a stick or a metal hanger to remove the blockage.
4) If the wand is clear, stretch the hose out and look for dark spots - those are the blockages. Again use a long object to remove the blockage - be careful not to damage the hose, you don't want to buy a new one.
Jun 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum is whistling and there is no suction through the hose.
Sometimes mine "wand" has no suction too. . . Make sure the vacumn column is clicked into the "standing" position, don't have it at an angle. Also you may have to play with the settings on the bottom part AND the power button together. I think this vacumn sucks (pardon the pun) mine turns off after 10 minutes of use, then I let it sit for an hour and then it'll start again. POS!
Apr 22, 2009 | Fantom Vacums XT450K Upright Vacuum
Vacuum not picking up
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Jan 19, 2009 | Kenmore 22512 Bagged Canister Vacuum
Fantom Vacums XT450K Upright Vacuum Logo
446 people viewed this question
Top Fantom Vacums Vacuums Experts
Richard Agent
Charles T Nevin
Charles T Nevin
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
