Question about Freezers
Freezer problems big time
I just learned about your website----I don't know if you can help me, but it's worth a try. We went on vacation for 2 weeks and inadvertently turned off the upright freezer. When we returned we were met with the most foul odor you can even imagine. We have cleaned up the mess----put "odor-rid" on the concrete after we tore out and discarded the carpet (the "juices" leaked out and into the carpet beneath the freezer. We are still having odor issues with the freezer. We think we need to replace the seal---that's $60---we don't want to do that if the freezer cannot be saved. Are we barking up the wrong tree---is it possible to save the freezer (it's only 2 years old)? We took out all the baskets and shelving materials---we washed them and the walls and outside of the freezer with soda in water. We've washed everything at least twice. The baskets and "things" still have an odor about them---some of the shelfing is plastic and I'm assuming it has absorbed the smell. If we take it outside and open it up to air out, will that be good enough? We could really use any advice you can give us. Thank you so much----I'm simmering cinnamon sticks and whole cloves all day long, but the smell is still there----I'm guessing that will just take time---like when you burn popcorn in the micro-wave. Thanks. Linda D.
Try putting a tray of crushed charcoal in there... a one foot by one foot tray about 3 inches deep filled with crushed BBQ briquettes (the kind that doesn't have lighter fluid in it!) left over night or longer may pull much of the "stank" out, and you can always do it again with fresh charcoal if it works but not well enough... Good luck!
Posted on Aug 19, 2008
We ve had the Bosch fridge-freezer (KGU3201GB/01) for about 10 years. Suddenly this morning the freezer started losing temperature, which rose to -13 degrees and the alarm went off. We put the...
Hi Robert, sounds like the unit is not defrosting.
Try this to indicate defost issues.
1. relocate food in the freezer, turn the unit off for 2 days and leave the door open, this will allow total defrost.
2. clean, then restart unit with door closed, after and every 2 hours check temp, I feel you may find it will get to its operating temp reasonably fast and should stay there.
If this is the case, I suspect the defrost heater element has failed and needs replacing, this is the most common cause of your type of issue.
Hope that helps and please dont forget to vote. Regards Russ
Mar 19, 2011 | Bosch 3.2 cu. ft. / 91 liter Upright...
Went of vacation and just returned to a puddle of
your ptc relay and contactor on the compressor body is defective,unplug the unit,remove the spring wire or clip that holds it onto the compressor and install a new one,also if it has a run capacitor replace this also
Mar 18, 2010 | Freezers
Whirlpool Freezer went from -18C to -3C over 2 weeks. Defrosted
Got my mate electronics exoert to check the circuit board, he found the fautly part and replaced it - cost ZERO
Jan 01, 2010 | Whirlpool Freezers
Sub-Zero 550 Freezer not cold enough
Start with the simple items first like checking the coils at the back of the freezer for ice. If there is let it melt away by unplugging the unit. Have the unity cleaned at that area whether there is ice or none and the entir fridge including the drains on the freezer. Then start the unit again.
Aug 31, 2009 | Freezers
My ice machine only harvest 2 time and start to 3 beep eveaperater very clean no scales inside because i descale every 2 weeks can u help me
In most cases, there is a chart on the inside of the front cover. It may also be located on the side of the box where the control circuit board is located. It will tell you what the 3 beeps mean. Hoshi has a great tech support. It's worth the wait.
Feb 02, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Freezes for 7 to 14 days then just quits!
hate to tell you but your compressor is going out on your freezer ,,, i'd look for another freezer.
Larry
Oct 28, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Fridgidaire upright freezer alarm FFU2065FW
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one of these:
The compressor,The Thermostat,The overload, relay, or capacitor,The defrost timer,The condenser fan motor.
Try to troubleshoot each of these componet one after the other using eliminating method.
That may solve your problem.
Jul 23, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer Not Working
The most likely answer is a slow freon leak assuming it was getting to the right temperature before you went on vacation.
Jul 16, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
GIBSON DEEP FREEZE IS RUNNING BUT EVERYTHING IS THAWING OUT
Might try unplugging for a few hours and then plug it back in. There is a possibility that it slugged the compressor and there is a restriction in the line. Sometimes when the compressor fails to stop running in cold air the liquid gets back to the compressor. It can cause a bit of gunk to be picked up out of the oil and carried to the expansion line and plug up the line. Maybe turning it off will let the plug fall free and not replug the line. Worth a try anyway.....
Feb 07, 2008 | Freezers
Freezer making noise & left side of the freezer (on outside is very warm to touch)
Sounds like the freezer evapurator fan... they make noise on and off at times when bears are wore... Thats about the only thing that can make noise inthe area ur talking about.. if noise comes back listen where the freezer fan is.. is most liklly the problem
Nov 02, 2007 | Freezers
Freezers Logo
123 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
