Question about Husqvarna Viking 1
Viking Sewing Machine Model 6360
Feed Dogs do not go "up & Down" when sewing. Took of throat plate and lower housing -cleaned everything. The feed dog "lower button" takes it down but when releasing it, I have to put my fingernail under it to raise it into "up" position. Could there be something disconnected in the right end where the "arm" origionates? This machine is so old I hesitate to take it in and put any money into it. What do you think?
There is a white button on the front of the machine to the right - it has likely been pressed in to drop the feed. Press it in and release so the button comes out - that should solve the problem.
Posted on Dec 11, 2008
I lowered the feed dogs on my Juki TL-2010Q to free motion quilt and they won't raise. I cleaned under the throat plate. Help?
Have you tried sewing with it since you "raised" the feed dogs? The feed dogs will not raise until you begin to stitch.
Mar 12, 2017 | Juki Sewing Machines
My feed dogs will not pull my material through.
Check to be sure you have not inadvertently dropped the feed dogs on your machine. Dropped feed dogs are used for 'darning' or 'free motion quilting.' Below is info from Troubleshooting Manual:
Fabric does not feed through the machine
The feed dogs are lowered. Use the feed dog position switch to raise the feed dogs. 81
The stitches are too close together. Lengthen the stitch length. 42
The wrong presser foot was used. Attach the correct presser foot. 179
The needle is bent or blunt. Replace the needle with a new one. 34
The thread is tangled. Use scissors, etc., to cut the tangled thread and remove it from the race, etc.
Apr 11, 2015 | Baby Lock Esante
Will only make very small stitches even when set on 4.
With no make or model, it's guessing. First remove throat plate under presser foot that needle passes through, check for lint on feed dogs and in between feed dog teeth. Next l would oil feed dog mechanism, turn hand-wheel with throat plate removed and look for parts that rub. Lubricate with sew machine oil. Hope it helps.
Apr 02, 2015 | Sewing Machines
I have been sewing all morning. Suddenly the fabric does not feed everything is clean
Look at the feed dogs to see if they are rising above the needle plate at least 1 mm. If not rising lint may have felted between the feed dogs and the needle plate. It could also be the feed dogs have been lowered, or the height has slipped. If the feed dogs are above the needle plate turn the hand wheel and see if they are moving from the front of the machine to the back. If not it is a length adjustment. If this is normal the pressure on the fabric may be too low. Another problem may be the timing of the feed dogs. The feed dogs should rise above the needle plate when the needle leaves the fabric and descend when the needle comes down into the fabric. This requires an expert to fix.
Mar 15, 2014 | Euro-Pro Shark 60 - 384
Feed dogs will not raise, I have lifted the presser foot, pushed the feed dog lever to the raised positon and turned the handwheel till i heard the click. They still will not snap into place in the raissed...
Hello
First, lift the presser foot; next, push the feed dog lever to the raised position; finally, turn the handwheel towards you until you hear the feed dogs snap into place
If it doesn't, you will have to run a maintenance check on your feed dogs,
Unplug the machine and examine the feed dogs. The newer machines have metal feed dogs, but older models may have rubber ones, which often need replacing. Examine the feed dogs and check for damage.
Remove the throat plate, which is the covering over the feed dogs, and clean it with a soft cloth. Use a small soft brush to clean the feed dogs. Make sure to remove all lint and thread from the grooves of the teeth. Some machines have an adjustment that lowers the feed dogs for specific sewing procedures. They should be in the raised position for better viewing during the cleaning process.
Clean the area around the feed dogs with a soft brush. Compressed air is a good choice to use in the small tight areas.
Wipe down all areas with a clean, lint free cloth before replacing the throat plate.
Prepare to clean the feed dogs and all other areas that lint may accumulate on, after every project. Your sewing machine will last longer and need fewer repairs if kept clean and lint free.
Always unplug the sewing machine before any type of maintenance or cleaning.
Never use a sharp tool when cleaning the feed dogs as this may cause damage to the sewing machine.
Apr 16, 2011 | Singer 7436 - INGENUITY
Kenmore model 158 15510 will not catch the material to advance it while sewing. The catch plate does not go up high enough.
Feed dogs.
Check the manual for how to engage/raise the feed dogs.
Or, it could be the machine needs cleaning.
Open the bobbin area and the throat plate (plate under the presser foot) and clean with a soft brush or cotton swab.
Apr 25, 2010 | Sewing Machines
Stippling for Viking emerald sewing machine
The switch in the back will lower the feed dogs.
If you need a manual - I found a PDF download by googling: viking emerald 183 manual
Feb 23, 2010 | Husqvarna Viking 1
Removing needle plate from viking sewing machine
throat plate is usually tight with screws may be that the holding magnet and once the button is located near shuttle and it should press plate up...
Dec 24, 2009 | Husqvarna Viking 1
The fabric does not feed properly.
Remove the throat plate and clean out the lint in between the feed dogs (teeth). Make sure the throat plate is not bent downwards where the needle goes through. Also, after removing the lint turn the machine over by hand, the feed dogs at their highest point should be about 2mm above the throat plate.
Also, try this link, there are many free books.
http://www.singermachines.co.uk/Parts_&_Ser/indstbooks.htm
Jul 06, 2009 | Singer 3116 Simple
Feed dog
There is a black lever behind, above and to the right of the needle.
Aug 24, 2008 | Kenmore Sewing Machines
Sewing Machines Logo
281 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
