Question about LG Dryers
LG TD-C70045E Condensing Dryer does not heat up, how do I fix it? All other controlls work fine just no heat.
  • 3 Answers
If not turn the power off and pull the dryer out and take the back off and push the red button in at the back
Posted on Aug 22, 2010
Water doesn't go to water tank. Any advice? thanks a lot Peter. LG DRYER TD-C70045E
Try unscrewing the water hoses and cleaning or replacing the filter screens where they screw into the unit and also the valves.
Aug 28, 2011 | LG Dryers
LG- CONDENSING DRIER- TD-C70080E DRIER IS NOT HEATING UP AT ALL CAN YOU HELP?
I think you're talking about gas Dreyer
Check the entrance of gas
Dec 28, 2010 | Dryers
Hi I have an LG TD-C70045E tumble dryer. The drum appears to have dropped slightly and I can see it is sitting below the metal pegs at the back. Someone looked at it and said it was the bearings and as the...
Rita,
The problem you describe really does not worth fixing since the parts ad labor should cost you over $400 and that why your tech told you it should be replaced.
There is no need to open the back (even if it looks better for the customer :) ) to diagnose this problem.
As an Appliance Repair NY company we see a lot of issues like that everyday and we also recommend to replace it.
You can purchase a new dryer for a little more and enjoy a brand new appliance.
You can see prices and brands over here: Dryers
Oct 05, 2010 | Washing Machines
LG TD C70045E dryer not heating up, this has happened before and the guy just pressed a switch but cant remember where it located, please help!
On the LG TD-C70045E the reset button for the heater is located inside the back air-way cover. This is easy enough to remove and the button is obvious once the cover is off. The button will 'click' satisfyingly if it has tripped. Don't forget to switch off and unlug first...
Aug 22, 2009 | Dryers
LG TD C70045E problem
Fluff has blocked the drain hole into the water drawer.Try locating the hole and using a small bore plastic tube **** the debris out of the container.
Feb 21, 2009 | Zanussi TC7102W Electric Dryer
Clean filter light stays on LG TD-C70045E Dryer
I had the same problem. It actually has nothing to do with the filters. If your dryer sounds like it wants to start the capacitor is blown.
Dec 07, 2008 | Zanussi TC7102W Electric Dryer
Lg td-c70045e electric dryer power on but not turning
I had the same problem. Replaced the capacitor and now all is ok. Dryer is working 100%. If you hear a humming sound from the motor then it means the capcitor is faulty and does not start the motor properly.
Oct 24, 2007 | Dryers
Dryer heats but no condensing of steam
The cold water feeds for condenser cooling and for wash cycle drum fill are controlled by separate solenoid valves (manifolded together at the cold water inlet hose union). When the solenoid on my condenser coolant valve failed a couple of years back, I got symptoms like yours. A new pair of valves isn't expensive to buy and is a trivial job to fit. If this is what has been happening, suggest you also inspect the insides of your dryer fan and of the pump - neither of mine took really kindly to having been cooked for hours on end. Alastair.
Oct 16, 2006 | Candy DQW150 Front Load Washer / Dryer
Dryers Logo
393 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
