Question about Frigidaire GLTF2940ES Front Load Washer
Error code E20. This is not listed on the error code chart. What do I do to fix the problem.
  • Anonymous Aug 20, 2008
    I have the same error code E20, all i know is it won't allow my washer to spin!
  • 876 Answers
E20 means the drain hose is plugged or kinked or the household drains are plugged. YOur washer will not drain and spin until this is fixed.
turn off the washer/unplug it/remove the drain hose and check for a clog. If it is there, clean it out. If not - check your sinks and toilets for slow running drains. The garbage disposal is a good place to start as well. plug the sink, fill it with hot water, then pull the plug and start the disposal. That will help clean the disposal and also show you if you have a drainage problem there. Plunge the toilets, etc.
Good luck to you!
Posted on Aug 22, 2008
SOURCE:
Gltf2940es3
good day,
no idea for the E20 error coz all brand have diff error code?
call the service center what the exactly the E20 error?
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
Nov 01, 2013 | Washing Machines
Frigidaire front load washer (ATF6000SF1) error E20
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Nov 29, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
My washer does not drain or spin. I get an E20 error code everytime we use it.
Hi-I am just another owner. The E20 code means that the waste (drain) line has an obstruction. This can be the hose kinked, or in my case it was a frozen waste line. In my case the _1160.jpgsolution was thawing the drain pipe...you might be lucky to find it is a kink or chunk of something plugging your output drain. Good luck! FYI-I got this info from the Error code chart that was a single sheet packed with the manual of my washer. I will try to attach a copy of the English part if I can get it to the limited size accepted here for attachment. (well, that is not where I intended the chart to go, but I hope you can read it!)
Apr 13, 2011 | Frigidaire GLTF2940ES Front Load Washer
Error codes E20
Hi
Error code e20 means a clogged drain pump. This might have happened due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then remove whatever is there in the pump. Hope this helps... Please post back for any further assistance.
Nov 27, 2010 | Washing Machines
Zanussi turbodry 1200 There was a first error message E20, while drying, so i stopped the proccess but now in a new washing cicle, i´ve the same error while filling Whatt is E20? what must i...
Hi
Error code e20 means a clogged drain pump. This might have happened due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump. Tilt the machine on its side and remove the 3 screws and 2 wires that hold the pump in place. Hope this helps... Please post back for any further assistance.
Daniel
Nov 16, 2010 | Washing Machines
Error code e20 model # gltf2940ee0
Hi
Error code e20 means a clogged drain pump. This might have happenned due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Daniel
Jul 28, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a 97 Buick Regal and I get a E20 error message:cd player
If the CD is over 60 minutes it will not play on domestic cars
May 29, 2009 | 1997 Buick.5 Regal
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Frigidaire GLTF2940ES Front Load Washer Logo
283 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
