Question about Lands Phones
How to connect to the wifi with 3g iphone - Lands Phones
  • 827 Answers
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Posted on Jun 03, 2011
SOURCE:
My iphone 4s will connect to my wifi but cant download anything new - yet works fine on 3G
check the settings of the wifi ( make sure thats DHCP) in the wifi menu
good luck
Feb 13, 2013 | Apple iPhone 3G
Trying to connect my new iphone 3g to my home wifi network.. it confirms that it's connected in the settings (check mark next to the connection, etc), but it's still doing 3g for the actual connection (in...
If you're not gonna need the 3G network, you can turn it OFF by going to Settings>General>Network>
... you will see there all the networking switch. Turn OFF 3G by tapping the switch.
For more iPhone / iPod touch tips, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: [email protected] or add me on Skype: ebayseller.ca
Oct 02, 2010 | Apple iPhone 3G
My Iphone 3G won't connect to home wifi after working well for months. In settings, it searches indef. for networks. 3G works fine. My husbands iphone works fine. Any suggestions?
you can try to set your wifi same as your husband's one, check the wep code and wifi shold be enabled.
try this and give feed back!
good luck
Jun 30, 2010 | Apple iPhone 3G
Iphone / WiFi signal / Motorola SB5100 problem
Try turning 3g off, then make sure security of network is wep not wpa personal the iphone has trouble with that
Dec 14, 2009 | Apple iPhone 3G
UNlocked 3g iphone 16gb 3.0.1 WIFI NOT WORKING
You can try this site....
http://www.redmondpie.com/jailbreak-iphone-3.0.1-firmware-with-redsn0w/
Sep 20, 2009 | Apple iPhone 3G
Wifi on iphone 3g is not picking up wifi signal
it may be finding it but not showing the passcode screen to enter your wep key.
tap the wifi settings and set you network information and the wep network key which is located on your router.
If you put any other code in your wifi won;t connect.
Jun 10, 2009 | Apple iPhone 3G
Internet on iphone 3g??
Simply go to Settings > Wifi. If Wifi is off, turn it on. You'll see a list of available networks when you're in a hotspot. You can also have iphone tell you when you're near hotspots by turning on "Ask to Join Networks." You won't be able to use the internet when you're not in a wifi hotspot.
Oct 28, 2008 | Apple iPhone 3G
Wi-Fi 3g
Your iPhone will automatically switch to the WiFi setting if it is there! No need to turn off the 3g it will use your WiFi 1st, and 3g 2nd!
Aug 01, 2008 | Apple iPhone 3G
GPS not working
Try this -
1) Settings > Enable 3G Change to Off.
2) Use the iPhone GPS receiver to locate your position
3) Settings > Enable 3G change to On.
There are two positioning systems in the iPhone 3G, one is the 3G network, and the second is the GPS receiver. The problem occurs when the data from the two systems doesn't match.
Jul 14, 2008 | Apple iPhone 3G
Lands Phones Logo
472 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
