Question about Cell Phones
My lg viewty doesnt connect to the music manager , so i cant put music on my phone.
  • Anonymous Dec 10, 2008
    It was fine-converting from itunes to music manager until now. Now, when I attempt to connect, there's a sound on the phone with the message 'disconnected' . Help??????? this phone is the lg viewty
  • Anonymous Apr 09, 2009
    Doesn't connect at all ! :@
    Brigadier General:
  • 7,752 Answers
Try downloading the usb driver for the lg from the lg website
Posted on Aug 17, 2008
SOURCE:
I cant put music on to the lg viewty KU990I ! Any help ??
I find the easiest way is copying the music over manually rather than a fiddly program.
First, go to settings > phone settings > connectivity > USB connection mode, and make sure "mass storage" is selected.
Now plug your phone into the computer using a USB chord. The autoplay menu should pop up, otherwise go to my computer and open the "removable disk". Then go to the music folder within that (if there is none just create a new folder). Now just drag and drop the music you want on your phone and vwala.
Hope that helps!
Jun 22, 2009 | LG KU990 Viewty
Dowloading music to the LG viewty KU990
Have you put in a memorycard? You can use the phone as a hard drive only when a memory card has been installed on it.
If not you can only download music on your Viewty by using the LG Suite software that came with it which is very slow.
After you have put in a memorycard go to PhoneSettings and something called "Connection" right below Security. Then tap USB and then MassStorage. Connect the phone to your PC by a USB cable and now you should be able to transfer anything from your pc to your phone by dragging and dropping.
I have not tried WMPlayer but would not be surprised if it will just work fine.
Hope this helps,
Jan
Netherlands
May 30, 2009 | LG KU990 Viewty
Songs not showing on phone
It may be that the songs are in the wrong format.
May 23, 2009 | LG KU990 Viewty
I would like to put songs on my LG viewty using LG PC suite, how do you do it? I've installed it correctly i just don't know how to use the music manager, please help!
not possible, do u have a memory card? if so, go to: menu/options/phone potions/connections/USB connections and select mass storage. now connect to computer. co to my computer, and you will find: a new disc called "R" or "Q" i THINK. if this won't work contact me at my youtube account: addol95
Apr 19, 2009 | LG KU990 Viewty
Please help, i cant activate use of my memory card on the lg viewty
If its a new card, have you formatted it in the phone? (go to Menu, Settings, Phone Settings, Memory Manager, External Memory then click on the Format button).
To activate its use, go to Menu, Settings, Phone Settings, Memory Manager, Primary Storage Setting and select External Memory.
Apr 16, 2009 | LG KU990 Viewty
LG Viewty pc connection problems
Hi, I just had the exact same problem..
I tried like FOREVER and I even said, if this try doesnt work; i'm giving up, and then... it finally worked.. haha :) so, this is what I did.
(dont connect your phone yet but set your phone as data service) You open the program LG pc suite, and then click connection wizard > usb > and then here, you connect the both ends of the usb.. one end on your pc and the other on your phone, and then you press next. Hopefully it says something like Com Port Number and Phone Model. You click next and finish. So, now you are connected to the phone to your pc. To get photos to your pc, you click content. images. and copy and paste to where you like (pictures in your pc) and then your done :D this also goes to other files too :D if this doesnt work, then go to your right top corner box, close all applications and go to home screen! :D
I hope this really helped because I just learned it few minutes ago and I was about to scream because I tried so many ways. Hope this helped and Good Luck :D
Feb 16, 2009 | LG KU990 Viewty
Connection to music manager LG U 990 viewty
You could just manage your music files through 'Mass storage' mode...
I know it doesn't solve the problem, but it should be a useable workaround.
Is there some reason you want to use the LG Suite?
It's a complete pain in the backside even when it's working well.
Nov 08, 2008 | LG KU990 Viewty
Cant transfer music file to my lg ku990 via usb from pc to phone
Instead of loading the music manager, click on file in the LG Suite box, and then click 'content'. This will connect without a problem (at least it did for me, despite music manager not working), and then drag and drop music from your pc files, onto your phone. Hope this helps.
Jul 27, 2008 | LG KU990 Viewty
My lg viewty
why doesnt my pictures from my phone transfer onto my computer??
Jul 15, 2008 | LG KU990 Viewty
Downloading music from my pc to my LG KU990 Viewty
open your itunes or your music folder and just drop and drag them into the music manager
Jan 12, 2008 | Nokia 1600 Cellular Phone
Cell Phones Logo
46 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
