Question about Uniden 5.8GHz Dual Cordless Phone
Buzzing in both phones
I just recently started having a buzzing in both phones. The noice is so loud that you can hardly hear the other party when talking to them. The problem is not in the phone lines since I have tried another cordless (Panasonic) to those phone lines and no problem. Also, I just put new batteries (fully charged) in both phones and still a loud buzzing sound. The phones are approximately three years old.
Thanks
Owen Cook
Chattanooga, TN
  • 2 more comments
  • omcjwc Aug 18, 2008
    I don't think that the buzz is a reminder of anything such as a message or missed call. The phone does not have a alert feature that I know of.
    Thanks
    Don't think that the problem is in the antennas as the antennas are rigid and have not been bent or broken.
    Thanks
    Problem still not solved.
    The problem is not is the phone wiring or the telephone jack. I have used another portable phone, Panasonic, using the same wiring and jack, and do not have the buzzing on that phone.
    Thanks
    Sergeant:
    Champion:
  • 258 Answers
Have you tried the previously suggested solution of changing which channel the phones are set to?
Ken
Posted on Aug 18, 2008
  • 1,031 Answers
The buzz sound may be due to interference on the signal from wireless device,bluetooth,infra red,computer ,electronic devices ,so you can isolate the phone phone from this devices or change location where you have low interference and see the effect
  • Starnley Johnwells
    Starnley Johnwells Aug 18, 2008
    Cordless telephones use radio frequencies and have no FCC protection from interference. If you are receiving nearby transmissions on a cordless phone your only recourse is to contact the manufacturer for assistance. good luck
    Genius:
  • 1,269 Answers
Replace/Redo wirings. Use new phone jacks and RJ-11 connectors
    Genius:
  • 1,665 Answers
did you solve your problem or need further assistance?
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Aug 18, 2008
    Perhaps its an external intereference result. So try to move base to another location, or take away any other electrical appliance from phone base and test again its operation.
  • 6,487 Answers
After you check the suggestion of Expert Voodoomox and still have the same problem, you can try to reset the unit follow this steps:
1. Disconnect Battery from handset
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
Hope that helps.........
  • Mark Gil
    Mark Gil Aug 18, 2008
    Try following the other solution from other experts and also check my solution and that may solve your problem....
  • Mark Gil
    Master:
  • 382 Answers
Well its not a problem with your batteries exactly,One reason is as the phone is three years old,theres is fault in the connections and the second one is if you had dropped the phone down quite a few times then phone will starting to make a buzzing sound when you put it on which can be corrected with a service from a technican..thank you..
Regards!!....
  • Natesan Sabesan
    Natesan Sabesan Aug 18, 2008
    Also please check and make sure that there is no interference in the signal of the phone,make sure there is no interference of any elctronic device signals overlapping the device..Try to connect the phone in a different line if theres is no noise then the phone is perfect..Thank you..
    Genius:
  • 1,689 Answers
This answer is straight from Uniden.
The first thing you want to ensure is that the phone is not near any major electronics or appliances. Make sure that the phone is not tied in with a computer, fax, remote answering machine, splitter or caller id box.
Try pressing the channel button on the handset (if applicable to your product). On DCT models turn clarity boost on.
Make sure base unit antenna is in an upright position (if applicable to your product). If your handset does not have an antenna then make sure you are not holding the phone to where you are covering the internal antenna.
Try moving the phone to a different phone jack and outlet. If you have any other cordless phones in your home, try unplugging all of the phones except for the Uniden and see if there is a difference.
Finally, if you have computer accessories such as DSL, Wireless Network or Router these could interfere with the phone as well.
  • marlon john madrid
    marlon john madrid Aug 18, 2008
    please go through the posts we had earlier for the steps to follow and get the buzzing issue resolved.
    Hi OMC, i strongly suggest that you go through the STEPS we posted. let me put it in once again
    this answer is straight from Uniden.
    hope this works out
    Master:
  • 623 Answers
Check antenna for defects...
    Scholar:
  • 163 Answers
im working on your problem,
the batteries are not the problem for sure,
have you thought of this loud buzzer being just a reminder of some function of your phone?
such as message, missed phonecalls, maybe an alert (if phone features this function)
im working on you!
good luck
  • 1,800 Answers
Give Ur Both Phones a Soft Reset
Menu/Settings/Security/reset the phone
restore it to Full Factory Defaults!!
Our phone just started getting a humm loud noise you cant even hear your other party talk?
if you have the manual Check it to see what you have to do to change the channel the phone is using you may need to try several different ones before you get a quiet line. If you don't have the manual do a google search with you Phone brand and model # for owners manual.
Hope this helped
Jan 19, 2015 | Lands Phones
Hello, \r\nI have a 2003 dodge neon SE. I hear a loud roaring noice and vibration from the front end, the noise is really loud (like a truck) when I start it. When Car in drive the noice is loud but when I...
Hey Shona... Please take your car to a qualified professional... this could be something very serious related to safety.. do not take a chance.. let them diagnose your problem..please...
Jul 14, 2017 | 2003 Dodge Neon
Our Wii console is making a loud buzzing noice. I
I would suggest using a can of compressed air to clean the Wii out. The air should be able to clean out any dust bunnies and dirt that might be creating that noise.
If cleaning it doesn't help it might be out of your power and you'll have to send it into Nintendo. Nintendo's phone number is 1-800-255-3700.
If this helped, please help me and rate me.
Thanks,
Brandonmxb
Dec 12, 2009 | Nintendo Wii Console
Loud buzzing while other phone is on base. Switching phones on base has no effect on issue. Taking phone off base hitting 'talk' helps with issue, but buzzing returns upon placement on base..
did you have "buzzing" Before these phones? Anything electrical fan etc on the same circut breaker of your house?. Or buzzing start recently with these already running. It sounds like your describing "electrical noise" and not really a issue with the phoned them selves. Try relocating the base if you have another open wall jack and on another circut. If you notice it goes away check whats all on that circut (wall outlet) that you unplugged the base from. depending on the noise or lack of at the new location it would probly be something running on there. ..
Hope this gives ya a solid start on a fix :)
Nov 13, 2009 | Uniden 5.8GHz Cordless Phone
Can this be fixed
Try adjusting the volume not only on your bluetooth but also on your phone as well. The 2 volumes are not associated with each other at all. If that does not work still, your Bluetooth may not be compatible with your phone or you may have a defective bluetooth. Make sure you within 18 feet of your phone when talking on your bluetooth. Hope that helps!
Mar 18, 2009 | Motorola Mobility H700 Wireless Headset
Buzzing noise while making a call
This happens at many phones due to the speaker which buzzes because of the waves made by the conversation. For example try calling someone and be near a desktop pc speaker or radio and you'll hear the same buzzing noise
Feb 19, 2009 | LG Dare VX9700 Cell Phone
Can barely hear people when they call
The volume can only be accessed when you are in a call. Once you hear the call connecting or the other party has picked up, you will be able to change the volume. The volume control is the middle navigation key, use the left and right to control the volume.
Nov 10, 2008 | Nokia 6030 Cellular Phone
Uniden 5.8GHz Dual Cordless Phone Logo
238 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
