Question about Sony KP-61V45 61" Rear Projection Television
Sony kp-61v45 Blue Convergence off by 2 inches
I have the Sony kp-61v45. It was purchased in aug of 1997. Recently the tv has a 3D shadow. When looking at the convergence the BLUE was about 2 inches off to the right. When adjusting I CAN go up/down left right but when going all the way to the left I am still about 1 1/2 inches off.
From reading here and other places I did find that the common problem was the IC's and possibly the 2 Pico fuses. So I ordered then.
1) I checked the Pico fuses and they did om ok so I did not replace them.
2) I replace the 2ea old STK392-110 with STK392-180 (from reading it was noted these are BETTER are they??)
3) I replaced the IC's and turned on the unit.
4) Went in the Service menu and did a reset
** I still get the same issue with the blue. It almost looks like the blue is another 1/2 inch to the right. I still can move up/down left/right but, am still around 2 inches off. (see Pic)
** Should of I replaced the Pico fuses anyways????
** Any idea on what to replace next ?
Any help / suggestion anything would be great!!! I am willing to try anything and order any other part and if you are in the Chicago area let me know.
  • j_internet Aug 27, 2008
    hhmm.. Was not able to find a adjustment. Only for focus not up/down/left/right.
    Any other suggestions??
    Which board is the Convergence board the one in the back with the STKxxx on them or a board in front of the unit ?
    Scholar:
  • 167 Answers
Hello from what you have talked about. your problem sound's like it's in the convergence .? but it could be that the blue (CTR GUN) IS OUT OF ALIMENT.!!! THERE ARE AJUSTMENT.!!! ON THE BLUE (CTRGUN ) ON THE TOP OF IT.!!! TO AJUST IT TO THE RIGHT DEGREE.!!! WHERE IT LINE'S UP WITH THE GREEN & THE RED . IN A CROSS PATTREN . !!! THAT'S WHAT THE CONVERGENCE DOS'E .!!! THAT MAKE'S YOUR PICTURE.!!! HOPE THIS HELP YOU!!! . LET ME KNOW OK !!!"GOOD LUCK"
Posted on Aug 17, 2008
    Genius:
  • 2,920 Answers
You need to replace the convergence board its around 80 dollars
SOURCE:
Tv shows images in red, blue and yellow colors only
Tv have a problems known as a convergence picture problems,it is dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead.This tv convergence board must be repairs,u must require to replaced components parts like 2 STK convergence ICS and some or all of it resistors too.To fixed the the tv convergence board to solved the tv convergence picture problems.The shop,will cost like $300-350 for parts and labors.
Jun 29, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Hello, I have a 2005 Sony KP-51WS520 Rear Projection TV. Recently, the green colors all become a yellowish/orangish color. When you are watching a baseball game the grass is a orangish color. ...
DLP tvs have a design weakness,the problems it is call a convergence problems,it is dead.This convergence problems,will have happen many times through out the tv live.The tv have a colors R,G,B lines misalignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv board,that call the tv convergence board it is dead.The tv convergence board,must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv colors picture convergencce problems.The tvs shops will cost u like $300-350 for parts and labors.
May 24, 2011 | Sony KP-51WS520 51" Rear Projection...
I have an RCA D40W20 HDtv with the same 3d looking convergence problem. Is mine as easy to do as the Sony KP-51HW40 solution from 2 mnths ago?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 26, 2011 | Sony KP-51HW40 51" Rear Projection...
How do i center the colors, red, blue and green?
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 15, 2011 | Sony KP-61HS10 61" Rear Projection...
The picture on our Sony TV Model KP-43HT20 recently became distorted, concaving at top and bottom. If I use reset the Flash Focus, the picture will return to full screen side for awhile but the colors do...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergene board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 15, 2011 | Sony KP-43HT20 43" Rear Projection...
My sony kp57ws510 model tv has double vision and the double vision that shouldnt be there is in blue and red..whats wrong with my tv?
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have shadows pictures or 3D pictures look alike.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors on the tv convergence board are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 29, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Blue screen for about a half hour and then still blueish color
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D look pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergencce picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 20, 2010 | Sony KP-65WV700 65" Rear Projection HDTV
My KP-62HS10 sony tv got picture smear and cook on right sight. i think some electronic part burn out ?
Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like?The tv have a problems known as a convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 19, 2010 | Sony KP-61HS10 61" Rear Projection...
I have a sony kp 48s and there seems to be a blue shadow on the picture?? i've tried everything in the settings to fix it but it just seems like a manufacture malfunction?
You probably need to get a Sony TV Convergence Kit. More information can be found using the link below.
Convergence Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 28, 2010 | Sony Televison & Video
I have a red shadow in 3d on sony KP-46WT510 TV.
Ur convergence is dead.Problems:Are 3D colors,colors misaligns,and colors out of focus.Know how to solders?Must change 2 convergence ICS,and some or all the resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 17, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Televison & Video Logo
139 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
