Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis dryer no heat
My electric dryer stopped heating... any suggestions.
  • jr22msm Jan 05, 2009
    I have the same problem....the dryer runs, but doesn't heat at all on any setting. My first thought was to check the thermostat and/or heating element, but I don't have any diagrams that show where these are located in my dryer. If anyone has any manual that shows where these are I'd appreciate it (the regular manual that came with it doesn't show where they are located).
    It's the Maytag Atlantis...model # MDE7400AYW
  • brandbmg Jan 09, 2009
    I have the same problem of the dryer running, but not heat. My husband was messing around with it, and I don't know if yours is the same model, but ours has the moisture sensor. He found that when he opened the dryer and let it run (you have to hold the knob in for the light to do this) and he tapped his finger against the sensor, it's on the right side inside the door, the light matched his tapping, so I'm assuming that it might be the sensor itself that is causing the problem. Ours will heat for about the 1st minute or so of the cycle and then stops. Not sure if the sensor is replaceable, or something that can be done by the consumer or not.
The heating element and thermostat are located behind the front panel of the dryer. you will need to remove the door, then the retaining screws. the heater / element is located on the left side as you are facing the front of the dryer and has to sheet meta screws (upper back top / and front bottom) which will need to be removed. the unit has several colored wires for the thermostat and switch. remove these (remember which goes where) and the enitre unit will come out easily.
Posted on Jan 08, 2009
  • 594 Answers
Check the thermostat and heating element those are the main reasons a dryer will still work but no heat.
please do not forget to rate and comment about your experience on fixya.
Posted on Aug 17, 2008
Why does my Maytag Atlantis dryer not heat up at all?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 08, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Not sure what model is other than maytag atlantis but my gas dryer has quit heating therefore does not dry...any suggestions?
check voltage to dryer, should be 220-240. check element, thermal fuse. could be in the timer but rare.
Jun 26, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDG6400AWW, timer stopped working
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
No heat from dryer maytag atlantis mde7600ayw had heating element them fuse and thermostat checked ok check ciruit breaker turn on and off decided to replace fuse dyer still didn't heat check outlet...
most dryers have a thermal switch or breaker in the cavity somewhere, they can become worn over time and will stop heating, the item probably looks like a copper arm that touches a contact similar to a old morse code key by looks
Sep 18, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag gas atlantis dryer. It starts but after a
I love the Maytag Atlantis!!! This sounds like your motor may be bad. It's NOT the element or it would not heat at all. Hope this helps!
Aug 13, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Mar 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer does not heat
Perhaps the thermal fuse is open. All thermostats and thermal fuses should be closed for continuity at room temperature on this dryer.
Go here for more Maytag Atlantis Dryer repair help: http://www.repairclinic.com/0047_8.asp
www.RepairClinic.com
Feb 01, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis Dryer not heating up
Best guess is that one of the two solenoid coils on the gas valve is faulty, one has two connections and the other has three. Always replace BOTH solenoids even if only one has failed.
Aug 10, 2017 | Maytag Atlantis MDE7400AY Electric Dryer
I HAVE A MAYTAG ATLANTIS GAS DRYER STOPS HEATING ABOUT 5 MINUTES IN
the flame going out is normal. the heat cycles on and off as called for by the thermostat. If the heat doesn't come back on i would start by changing the gas coils.
Oct 08, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
1,311 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
