Code 95 on your 2010 Vauxhall Astra Life points towards a fault with the airbags; in other words, your airbags require servicing. To know more about the codeson your car and what they mean, follow this link: https://www.drivingtesttips.biz/vauxhall-astra-dashboard-engine-warning-lights-meanings/fault-codes.html
Means that you have 24 percent of life left on your transmission fluid.say it's good for 30,000 miles,you would have almost
7500 left till it needs changing.
It simply means that its time for routing service and maintenance on your car. This will normally be reset when you take it in for an oil change.
1. Ford has issued a Special Service Message (SSM), stating that the owner's manual procedure is incorrect, and giving a revised procedure. The following is the text of the SSM:
18562 2005 FREESTYLE/FIVE HUNDRED/MONTEGO - OIL LIFE RESET PROCEDURE THE 2005 FREESTYLE, FIVE HUNDRED, AND MONTEGO VEHICLE OWNER'S GUIDE OIL LIFE RESET PROCEDURE IS INCORRECT. TO RESET OIL LIFE ON VEHICLES WITHOUT MESSAGE CENTER, USE THE TRIP/RESET BUTTON TO TOGGLE THE ODOMETER DISPLAY TO 'OIL LIFE XX%'. THEN PRESS AND HOLD THE BUTTON FOR 10 SECONDS TO RESET TO 100%. THE INSTRUMENT CLUSTER WILL BEEP WHEN THE OIL LIFE IS RESET. FOR VEHICLES WITH A MESSAGE CENTER, PRESS 'SETUP' TO DISPLAY 'PRESS RESET FOR SYS CHECK'. PRESS AND RELEASE 'RESET' TO START SYSTEM CHECK. WHILE 'OIL LIFE XX%' IS DISPLAYED, PRESS AND HOLD 'RESET' UNTIL 'IF NEW OIL HOLD RESET' IS DISPLAYED, THEN RELEASE. PRESS AND HOLD 'RESET' AGAIN UNTIL 'OIL LIFE SET TO 100%' IS DISPLAYED. THE INSTRUMENT CLUSTER WILL BEEP WHEN THE OIL LIFE IS RESET. EFFECTIVE DATE: 04/20/2005
Meaning the life of the k drum is near and you need to replaced it soon or later
other message like below need attention
C DRUM LIFE
REMAINING nn%
M DRUM LIFE
REMAINING nn%
Y DRUM LIFE
REMAINING nn%
BELT LIFE
REMAINING nn%
FUSER LIFE
REMAINING nn%
K TONER
REMAINING nn%
C TONER
REMAINING nn%
M TONER
REMAINING nn%
Y TONER
REMAINING nn%
Refers to Magenta Drum/Developing assembly. Toner concentration within developing is low. Also can mean that the Drum Unit has exceeded its life. The code meaning will change to some degree depending on the specific model. On the Older CLC models that have Separate Developing Units the developer unit may need to be re-started. To check drum life. enter Service Mode by pressing on the Keyboard *28*. At next Screen touch "Copier", next Screen select Display. At the Display Screen select "Misc"
The drum life meters will be displayed. If the drum life exceeds 100% that could be the problem.
This is what helps the tech inspect your car. B Means to replace oil and oil filter. And inspect certain things on the vehical.
Sub systems # 1 Means rotate tires and check tire pressure. #5 Means Replace Coolant
What do you mean 15. Their is no 15 in the Maintenance Minder System.
To reset the Maintenance Minder System (your oil life) Make sure the oil life is displayed #1 Press and hold the reset button for 10 seconds until the oil life flashes #2 Press and hold the reset button for a additional 5 seconds.
