Tobisha model # tp48e61
I have a 1996 Tobisha model # tp48e61.The sound is fine,but all three bulbs are not working.There is no picture what so ever.Any thing i can do to fix this ?
  • eyezwide85 Aug 17, 2008
    How do i fix a convergence circuit my self is there a step by step guid i can find ? If so please help
    Master:
  • 623 Answers
Check the bulbs first...if their blown replace it
Posted on Aug 17, 2008
    Genius:
  • 1,689 Answers
From AllExperts
This is the convergence circuit going bad. it is very common on your model. a repair cost would range 300.00 this is too much to put into a tv of this age. you can fix this but only if you can solder good? and test parts with a meter?
hope this helps
    Genius:
  • 2,920 Answers
The main board is out it needs replaced a shop would need to do the repair.
  • Ronnie Houston Aug 17, 2008
    any tv shop in your area should be able to do the required repair and as there is high voltage in the back of the set if you dont know about them you could get hurt or completely short out the set
I have a Mitsubishi VS-7085 TV 3 Bulb projection, the tv was on working fine then the picture went out but we could still hear the sound and change channels what can I do?
look to see if the three tubes are lit or not, also see if picture on any input or just retire the set as somewhat old.
Nov 27, 2012 | Televison & Video
No picture, sounds fine. Fuse blown
This set, I am sorry to say has no bulb and has no ballast circuit. There are three picture tubes inside this TV set. What exactly was the part you pulled out? Can you post a picture of the Part you pulled out?
Jul 29, 2007 | Toshiba 46H84 46" Rear Projection...
Bought 40" TV was floor
Try going to Remotes.com they have original remotes for all major brands.
May 09, 2011 | Toshiba Televison & Video
I have a Toshiba model 65HM167. The bulb exploded about 6 months ago so I replaced it and everything worked fine until now. Now the TV will power on and I will get sound but no picture. The yellow light...
Unfortunately lamps go bad without the visible state of being bad. I don't know who or where you bought the lamp from but I order all my lamps through dlplamps.com
The clicking sound you hear is the lamp inverter igniteing the lamp but the lamp is bad.
Nov 29, 2010 | Toshiba 65HM167 65" Projection Television
Hi I need a replacement bulb for my WS-55411 Mitsubishi. Can you help me find the right bulb and it's part number? The screen blacked out and sound still works so I assume I need a new bulb. When I shop...
Your model doesnt have a bulb since its a rear projection TV . It has three picture tubes, However loss of video with audio still working is usually caused by a vertical output failure.
Jul 28, 2010 | Mitsubishi WS-55411 55" Rear Projection...
62SX4D with no sound and won't turn on.
Lamp would be the first thing to check but lamp failure will not cause the picture to be fussy. Lamp only affects brightness. Nor would it cause sound to go out.It could be several thing . Diagnosis by qualified serv tech will be required.
Aug 29, 2009 | LG 62SX4D 62" Television
No picture (fan& bulb do not come on) but there is sound
I have a RCA 52inch D52w136D, the power button blinks three times, but nothing happens no picture or sound
Nov 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture on Samsung HLN5065W
sounds like the color wheel has gone bad..the part is not very expensive but it takes some work to replace it
Nov 29, 2007 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
