Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Hitachi 60V500A
I have a Hitachi TV Model 60V500A, I buy i 2005 and change the lamp in 2006. Now the pictuture is to Red and do not look good.
ATT;
J. Joaquin
San Juan, PR
  • 927 Answers
Good Day, artisticpool;
Suspect loose cable see picture:
If okay suspect light engine.
Good Luck, big IRISH.
Posted on Aug 19, 2008
Can't local the bulb, so i can replace it in my tv. hitachi 60v500a
From the front on right side look for and open the door that covers it.
Dec 16, 2012 | Philips Hitachi 60V500A Bare Lamp UX21511
Light is dim for hitachi model 60v500a
you need a new lamp, USD130 for a new one
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jun 24, 2012 | Hitachi Lamp for Hitachi 60V500A -...
My TV is Hitachi 60V500A rear projection TV. I replaced the bulb but still showing lamp light. What should i do?
Remove the lamp cartridge and make sure the wiring is secure, if ok then reinstall, slowly and carefully making sure the lamp is seated correctly, do all this while the tv is unplugged - of course, also make sure the all the covers on the tv are securely installed or the tv will not power up. good luck
Nov 06, 2010 | Hitachi 50VF820 Projection TV
Hitachi tv LCD blinking red light tv wont' turn on. replaced lamp model 60V500A
I have hitachi lcd rear projection tv model 60v500A at first I was getting a red spot on centar of tv with in two mounths the spot got bigger. I chanched the lamp but now i don't have a picture, the red indicator on tv is now blinking.
Aug 10, 2010 | Hitachi Televison & Video
How to fix a hitach tv
Did you make sure to put the lamp door back on? There is a safety switch that will not allow the set to turn on when the door is off. If that isn't it, then you could have a bad lamp ballast or even a bad lamp door switch. I would start there. If no luck there then you most likely have a problem on the power supply module, which could be just about anything on it. Good luck.
Jul 29, 2010 | Hitachi 60V500 60" Rear Projection...
Lamp light on after i replaced the blown lamp Hitachi 60v500a
Was the tv working before you replaced the lamp? if it was then make shure you have reinstalled the new lamp and the door exactly as removed, there is a disconect switch on the door that has to close when the door is reinstalled,or sometimes the ballast may go bad at the same time.Hope tha t will help you fix it.
Mar 19, 2010 | Televison & Video
My Hitachi 60V500a would not turn on . I was thinking it was the bulb .put a new bulb in and he TV still not come on the red lamp light is blinking. What do I do?
If its not Lamp ,most of the time its the Ballast Board it is what turns Lamp on. Go to Encompass Parts Distr website CK out your Model number see what they have in Parts or call 1-800-638-3328
Dec 01, 2009 | Hitachi 60V500 60" Rear Projection...
Hitachi model 60v500a.the middle of the screen is a little yello
If you Google "60v500a light engine" you will learn a few things about this set which was first sold in 2003.
There are some class action lawsuits out there for several Hitachi models made at about the same time.
Most of the time these sets develop a discolored area fairly large in the middle of the screen---a lot of them had a large red or pink oval area but other colors are possible.
This set uses a LAMP for the light source and it directs the light into the optical light engine--at the top of the engine is a 3 inch lens that the picture comes out of and is directed into the mirror which puts it on the screen.
Lots of these sets develop a "burn" inside the engine from the heat--there are a series of lens and baffles inside---even slight separation inside will change the color in some area of the picture.
I am sorry to give you bad news but I have replaced a lot of these engines under extended and when they were new mfg. warranty.
The part is no longer available from Hitachi new--the only way to get one is to remove the one in the set and have it sent out for "rebuild" and the last time I saw one the engine was over 600 dollars at the wholesale level not counting the fact that it is major labor to replace.
Find someone in your area familiar with Hitachi and this model and you will see what I am talking about.
Even though this is not good news, I think it is what your problem is.
If this helps you, rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Hitachi 60V500 60" Rear Projection...
Have a green tint over 90% ot the center of the screen
I had the same problem with my 60V500A about a year ago. The screen got a red tint in the center and the image was fuzzy in that area. A new lamp didn't solve the problem. I did some checking and found out that the original light engine used in this model had a cooling issue that could cause the light engine to overheat and distort the LCD panels. My warranty had run out more than a year before this happened so I figured I was screwed since the light engine was so expensive. I decided to call Hitachi tech support and see if I could get a discount on the cost of a new light engine since the cooling problem was a known issue for this model TV. I calmly explained to them that I was aware of the cooling issue in the light engine and that I felt like a $4000 TV should last more than two or three years. Tech support gave me the phone number for my local authorized Hitachi service center and I gave them a call. Once the technician confirmed that it was the light engine that was the problem Hitachi sent him a replacement light engine at no cost to me. I was WAY past my warranty period so I still had to pay for the labor to replace the light engine. $300 for labor was a lot cheaper than buying a new light engine or tossing the TV and buying a new one. I have to say that Hitachi earned my respect for admitting there was a problem and doing what was needed to correct the problem more than a year after my warranty had expired.
Feb 20, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
TH ETV TURN OFF ITSELF
the cooling fan could be going out
Dec 13, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
277 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
