Question about Sharp R420L Microwave Oven
I have a Sharp Microwave Carousel R-420B. I put a bowl of soup in , closed the door, pressed Minute Plus, and hit Stop with approx 20 seconds to go... pressed the door release but nothing happened... door did not open...
  • msmully451 Jun 03, 2011
    I tried but could not open the door... my wife and I pulled the button off, and with a flashlight, could not see any mechanism which would release the door... we tried prying the door open, but am afraid of breaking the door, or warping it to the point where radiation may leak..
  • Sharp Master
  • 19,396 Answers
Hi.
There is no mechanism that will release the door. The door interlock circuit is broken. The door lock on Sharp MW oven gets opened when the latch is energizing.
By prying the door you can compromise the good working of the oven. The Microwave must be disassembled. If the door is hiding screws holding the chassis together, the technician may decide to break the door latch (this is made of plastic) by grabbing the upper and lower side of the door, pulling slightly and helping with a flat tool. If the operation is done by the user there is an high risk to warp the door frame or the chassis, causing more damage.
In this case I suggest disconnecting power for ten minutes. Since that may not work, call Sharp service at the number listed on the owners manual to have the oven repaired by a professional.
Regards.
Ginko
Posted on Jun 03, 2011
  • Sharp Master
  • 6,993 Answers
Usually, the door lever or hinges is the cause of this type of problem.
But in this case, I don't think the door lever or hinge is the cause of your problem.
I think the door is jammed and only needs some force before is can open or unjam.
Use your hands or a flat Philips screw driver to forcefully open the door. Don't apply too much force. Just apply a reason amount of force that could open the oven door.
Before you attempt to forcefully open the microwave door, leave it for about 45mins to 1hr, after that forcefully open the door.
If the above doesn't help to open the door, please let me know so that I can direct you further.
I wish you good luck.
Regards.
Mine does this occasionally, and it's because the door hinges have got a bit out of line, allowing the door to drop slightly, so the catch mechanism won't quite disengage.
Look along the bottom edge of the door and see if it has dropped lower than the front panel next to it. Try applying a bit of upward pressure on the bottom edge with your fingers, while pulling towards you at the same time, and with your other hand press the release button.
If that gets it open, remove last night's failed meal, open the door fully and carefully force it up a bit at a time, to bend the hinges back to level - keep pushing the door back so it nearly closes, and look at the bottom edge to check on progress. When the bottom of the door looks level with the panel , try closing it fully and see if the release button will open it again.
SOURCE:
MODEL R-395Y sharp carousel microwave not working. All power outlets are fine. Please help, cheers lyn
I was unable to locate a service repair manual specific to your microwave; sorry.
You'll must likely have to find a Sharp service and repair center.
I've attached a link that contains the user's manual to your microwave...it has the phone number and address of Sharp; perhaps you can phone them and ask where a repair center is located.
This is the diagnostic check list Sharp recommends before calling for service:
SERVICE CALL CHECK
Please check the following before calling for service:
1. Does the display light up?
2. When the door is opened, does the oven lamp come on?
3. Place one cup of water (approx. 250 ml) in a glass measure in the oven and close the door securely. Oven
lamp should go off if door is closed properly. Press the INSTANT COOK/START pad once.
A. Does the oven lamp come on?
B. Does the cooling fan work?
(Put your hand over the rear ventilation openings.)
C. Does the turntable rotate?
(The turntable can rotate clockwise or counterclockwise. This is quite normal.)
D. After one minute, did an audible signal sound and COOK
indicator go off?
E. Is the water inside the oven hot?
If "NO" is the answer to any of the above questions, please check your wall socket and the fuse in your meter box.
If both the wall socket and the fuse are functioning properly, CONTACT YOUR NEAREST SERVICE CENTRE
APPROVED BY SHARP.
Sharp Carousel 395Y Operation Manual And Cookbook
Feb 22, 2017 | Sharp Microwave Ovens
Sharp Carousel Microwave I heated some food. It worked fine, and shut off when it was done. I took out the food. When I closed the door the light stayed on. Light will not shut off. I tried...
Sometimes the switch in the door latch sticks. Mine did that and I ust closed the door with just a slight more force and everything started working fine.
Mar 03, 2015 | Sharp Microwave Ovens
Sharp carousel microwave convection oven keeps blowing fuse
The service manual is here:
http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
You can get Sharp parts from Encompass here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
See http://www.microtechfactoryservice.com/cap_test.html
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
See: http://www.microtechfactoryservice.com/xformer.html
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
See this: http://031d26d.namesecurehost.com/mwd/doorsw.txt
Aug 01, 2013 | Sharp R-820BK Microwave Convection Oven,...
We have a sharp model 1470a carousel. we can enter data on the keyboard but the mwave does not staRT. eX: HIT 'BAKED POTATO', IT DOES NOT START. HIT 15 SECONDS AND THEN RUN AND IT DOES NOT START....
I would suspect that you have a bad door switch or mount, or perhaps the "Start" pad on your keypad is bad.
The quickest way to check is to hit the "Minute Plus" pad and see if the oven cooks.
If not, it's a door switch or switch mount issue, either the top or bottom one. See my complete text file on door switch trouble here.
If it cooks, then your keypad is defective. It is part number FUNTKB107MRE0 (note zeroes, not ohs) and you can order one from Encompass here or you can call them toll-free at 866-779-5835.
Oct 17, 2011 | Sharp R-1470 Microwave Oven
I have a 1995 Sharp Carousel R-1440. Our power went out then when it came on our microwave it no longer working properly. the clock works but when the door is closed the cooling fan starts running- it...
Yes your oven's controller is probably malfunctioning you need to replace the SYSTEM BOARD but I personally suggest to buy an other oven.... the system board will be hard to find and expensive...
See if other electronics is acting funny since the power loss... you could CLAIM the damage from the insurance company
Good luck!!
Feb 28, 2011 | Sharp R-1460 Microwave Oven
Sharp Carousel 2 Convection Microwave R-1810 (Feb 86): all setting run for only about a minute and you have to hit the start every minute until you reach desired heating time. Toss or fix? Thanks, Ron O.
Simple fix.
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
We have the service manuals for similar models and have uploaded them to our site here and here to help you.
Note that the part numbers will likely differ.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
If you need a damper motor, contact Encompass here or call them toll-free at 866-779-5835.
Aug 19, 2010 | Sharp Microwave Ovens
Sharp Carousel Model R-1440 won't shut off
Take it immediately to a local Microwave repair shop...looks like one of the circuits may have gone...otherwise switch off from mains
Sep 28, 2009 | Sharp R-1480 Microwave Oven
Display shows nothing, microwave cuts off
You need a couple of cheap microswithes that the door latches hit when you close the door and a new control for your display problem which sharp has had a problem with
Oct 30, 2007 | Sharp R-1405 / R-140 Microwave Oven
Sharp R420L Microwave Oven Logo
368 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
