Ligth flashing on power botton and do not turn on
  • 8,617 Answers
Whats the model number of your set, and how many times does the power light blink? Please respond to this same post
Posted on Aug 17, 2008
  • kenny bundy Jan 14, 2013
    HD-52G786 AND THE LIGHT IS FLASHING RAPID
My samsung RV511 laptop won't boot and the monitor keep on flashing on and off but the power indicator still ligths on
The monitor keeps flashing on and off? Or does your system keeps trying to reboot which causes the monitor to go on and off. Does the screen turn Blue before it goes off?
Apr 10, 2012 | Computers & Internet
Flashing ligth not working at all
Hi!!!
If your hazard lights turn on but do not blink, replace flasher.
If your hazard lights don't turn on, check hazard/stop/turn fuse(s).
Let me know how it worked out, good luck.
Mar 26, 2010 | 1998 Ford Windstar
My Dell? E198WFP Flat Panel Monitor the gree ligth on the power botton not working
green light on means your monitor showing display.change your button .your monitor working properly.
Jan 15, 2010 | Dell VOSTRO SLIM TOWER and , MONITOR 19...
Nintendo charges but doesn't turn on and both screens are ok
whats happening when you connect to a charger? if red ligth flashes that mean you have a blown fuse , if its solid red ligth that mean had a water damage or droppend , you will need to open up and put the loose part on the sopt , usually L1 next to power switch , REgards
Dec 08, 2009 | Nintendo DS Lite Console
Mitsubishi delicia 2.6 td (shogun engine). fails to release from 4wd so two front wheel lights flashing on dash. Its an auto but have tried usual things like re-engage then disengage and straight line...
Check the super select solenoids. I had the same problem with my pajero/montero io, when I released 4WD from 4H to 2H the two front wheels lights started flashing. They stopped flashing and was solid on when I re-engaged the 4WD (2H to 4H).
My problem was a failure in the 2H solenoid, it was not producing enough vacuum. The problem was intermitent at the begining and then was permanent.
I checked the solenoids in this way:
1) The solenoid that receives the vacuum in the botton is for 2H
2) The solenoid that receives the vacuum in the top is for 4H
3) Both solenoids operate in the same way, they only change in the way they transfering vacuum from top/botton to the exit pipe (2H or 4H). The difference is that one has the vacuum input on the top and the another one in the botton.
4) The default position when you disconnect the electronics is 4WD
5) Try disconnecting the electronics and switching the output pipe between the solenoids. This will put the solenoids on 4WD position and you changed the pipes, so the 4WD should disengage.
4WD should disengage if your 4H solenoid is OK, the ligths should now flash when you change from 2H to 4H because 4WD cannot engage because the pipes are switched. You can also check the vacuum of each solenoid with your finger on each one.
If this doesn't work, try to bypass the solenoids and connect the input vacuum hose to the 2H output pipe. If the lights doesn't turn off in 2H mode it's posible that you have different problem.
Also check this address: http://4wd.blogeasy.com/article.view.run?articleID=318776
Good luck.
Jul 25, 2008 | Mitsubishi Pickup Cars & Trucks
Hitachi T.V.
Good Day, halobeast044;
Replaced the LAMP. Good Luck big IRISH.
Jul 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Won't start when powered up
won t start when powered up , have ligth botton power
May 05, 2008 | Televison & Video
Blinking both the ink botton ligths and the botton paper
I just today threw away my R220. If your 2 red lights are going and the power light is off, then your printer has died. It just happened to me. It sucks, but there is no way to fix it.
May 04, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson GT30000 Document feeder error
if the ready light is off, and the error light is flashing, it indicates an interface error. please check all your cables.
Sep 16, 2007 | Epson GT 3000
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
