Question about True T-49 Side by Side Refrigerator Commercial
True t-49 refrigerator
Can my True T-49 side by side Refrigerator be converted to a Freezer.
  • 51 Answers
Yes it can. You would have to call a service company to recover the refrigerant, remove the oil in the compressor. They would then replace the oil as well as the refrigerant. The metering device would also need to be changed, along with the thermostat.
Posted on Feb 20, 2009
What is correct temp setting fpr t-49 true refrigerator
35 to 37 F. Put a thermometer inside and give it time like 2-3 cycles between adjustments before you believe the temp is stable. Hope this helps and good luck.
Jun 20, 2014 | True T-49 Side by Side Refrigerator...
Seperating Gaskets
Call True in St. Louis and get a name of a supplier that carries factory parts. After market just doesn't work as well as you've noticed. Hope this helps and good luck.
Apr 07, 2014 | True T-49 Side by Side Refrigerator...
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
What is the part number for timmer control of the T49 two door freeze
is it a Refr. or a Freezer for mthe freezer you can use a paragon model 8141-00-oem D-frost-o-matic timer control................good luck
Jun 15, 2011 | True T-49 Side by Side Refrigerator...
Freezer compressor runs loud and rough
Not if the repair was done correctly. The oil was probablly lost with the refrigerant and it sounds like it (the oil) wasn't replaced.
Mar 10, 2010 | True T-49 Side by Side Refrigerator...
Freezer compressor loud and rough
No it isnt, it sounds like he overcharged it. Call him back and tell him to try again.
Is the True T-49 prone to problems?
I believe you will be fine if you purchase any True, Trawselson, Delfield, or Hobart reach it. These are all name brand and I have seen them last for years.
Dec 06, 2008 | True T-49 Side by Side Refrigerator...
T-49 Freezer Lock
thanks for the question yes on both doors but nowhere else thanks the appliance doc
Sep 03, 2008 | True T-49 Side by Side Refrigerator...
True T-49 side by side is noisey
is unit cooling? if not suspect a deficient compressor. if it likes makes a rattling noise really loud suspect compressor wear hope it can help.
Apr 18, 2008 | True T-49 Side by Side Refrigerator...
True T-49 Side by Side Refrigerator Commercial Logo
169 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
