Question about HP DesignJet 750c plus InkJet Printer
Partial plot The plotter starts to plot, plots a partial area of the drawing and than stops. The display says : "printing" but nothing happens. He jams.
Hi, thanks for your answer. The plotter is connected via parrallel by a very long cable (33 feet) so I think that's my problem.
Since then, by the way, I didn't had the problem anymore and the plotter works perfect. If the problem starts again, I will use a much shorter cable.
Thanks again
Posted on Oct 23, 2008
  • HP Expert
  • 141 Answers
If connected via ethernet cable then i believe you have a bad network card, if connected via parrallel, then check to make sure the cable is not over 15 feet in length. also try to uninstall and reinstall the drivers on your computer as they sometimes become corrupt. Good luck!
Posted on Sep 14, 2008
Can not seem to fit the plot to the paper size.
I have solved the problem and are creating good plots
the problem was not with the plotter but the drawing had bugs
Thank You Jamie
Oct 23, 2009 | IMSI TurboCAD 2D Full Version Academic...
My plotter is recieving info. but takes forever to start plotting.
Try turning the nesting function off. This can save paper when you are doing high volume printing, particularly with smaller drawings but wil cause extreme delays if there isn't a steady flow of drawings going to the plotter.
Apr 14, 2009 | Computers & Internet
Hp design jet 750c plus. while plotting auto cad drawing,i command it to plot black/white (mono) but it plots all in color instead.I selected mono button on the printer as well.
Your plotter driver needs to be set to either black or greyscale. The driver will overide the settings on the plotter unless you set up the plotter in manual. ie the pen thicknesses, colour etc are set in the control panel to manual. The driver takes priority always.
Feb 20, 2009 | HP DesignJet 750c plus InkJet Printer
Why does the plotter use color even if we do not plot in color?
If you print in some CAD programm try the following....
Paper:Plain
Print Target:Line Drawing
Color Mode:Color CAD when the CTB is color and Monochrome when the CTB is monochrome
Resolution:Draft 600
For your situation use CTB monochrome and ColorMode Monochrome.
The print head prints max resolution 2400X1200
Jan 28, 2009 | Canon iPF700 InkJet Printer
Incomplete Plot of PDF file
This is a common problem on the 500 range, not so common on the 1050. A quick way around the problem (using the parallel port only) is to load the HP Designjet 750c drivers. Send the drawing to the 750 using memory in computer option and it WILL print.
Jan 12, 2009 | HP DesignJet 1050c plus InkJet Printer
Incomplete plot from .pdf file - Hp DesignJet 1050C Plus
Was the plot originally done on a size D or E plotter.. A .pdf is generally not a good way to send a plot that has to be done to scale.. Can they re-send the plot in a hpgl format, or a format that you can use in another program, liks ACAD, and then print it through that program? This would provide you with some control, that a pdf document will not allow.
This is just a stab in the dark for me, but I am familiar with plotters in general, just not the many formats to print from..
Nov 19, 2008 | HP DesignJet 1050c plus InkJet Printer
1050C plotter
Here is the drivers page if you need a new set:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=33712&locale=en_US&taskId=135&prodTypeId=18972&prodSeriesId=24023
Aug 27, 2008 | HP DesignJet 1050c plus InkJet Printer
1050c
check your rip settings in the plotters control panel, as well as checking to make sure you are using the correct driver, if those are correct then you may have a faulty network card.
Good Luck!
Jan 18, 2008 | HP DesignJet 1050c InkJet Printer
HP DesignJet 750c plus InkJet Printer Logo
161 people viewed this question
Seeker5211
Seeker5211
