Question about Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
My Makita handrill is not working. It's just like loose,and the drill is not rotating anymore.
  • ben_kash Nov 02, 2008
    The new makita LXT drills do not have a three speed transmission the have re designed and install a two speed transmission.  I have gone through 4 transmissions in a few years.  I am hoping I can contact makita and resolve it with them.
  • 115 Answers
Your bearings in the Clutch have fallen out of place.
Basically the tension screws pulling the clutch against the body.
Have became loose. If you Tighten them most likely wont fix it.
You should contact Makita. If you do open the drill. The Clutch assembly will be a task to reassemble. And the warranty might be voided.
Posted on Nov 29, 2008
My makita SDS rotary hammer drill leaves the bit in the hole while drilling. It is like it doesn't hold the bit anymore. What could be the problem and how do I disassemble the Chuck?
if you are using a normal 3 jaw chuck on the drill , that is normal when hammering
the vibrations loosen of the chuck
a method to stop it is to ensure the chuck is tight and keep pulling the drill out of the hole to remove the grit that jams the bit
Mar 08, 2017 | Makita Drills
Makita hr1260 drill won't rotate. how can I fix it?
have an appliance centre check out the drill motor as it may be burnt out.
Apr 22, 2015 | Makita Drills
I have a makita drill corded sds and hammer drill, the problem is that it hammers but has stopped rotating
It could be the pin in the lever on the side or a fault in the g/box. You don't say what model it is.
Apr 25, 2012 | Makita Drills
Bhp452 makita cordless drill smoking. how can i troubleshoot?
the switch or motor is wired incorrectly. These parts are polarity sensitive. The smoking I would assume is from the old switch and now the rotation is reversed. Let me know if you need more assistance.
Dec 10, 2011 | Makita 18 Volt Cordless Hammer Drill Kit ...
18v makita batteries will not charge anymore, can they be repaired?
Hello successfulpl, those batteries can not be repaired, but, they can be, and should be recycled.
Jan 13, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Quit working in first gear, I have 5 drills, the 2 speed models that no longer work in first gear. am I using it wrong or is it a product fault. they are 1 to 2 years old. We use them a lot, but they all...
my guess would be that if you use them a lot and have had them in service between one a two years they may have worn out. they use plastic and metal in the gearboxes and the collar that rotates to change the gear can wear out. i see tools that are used to make a living wear out have to be rebuilt untill they don't make the parts anymore.
Aug 09, 2010 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
I have a NiMH rechargeable battery for my Makita drill. It is a 9.6V 2.2Ah battery - they don't charge anymore. I don't know if it's the battery or the charger - how do I find out.
This happens regular with Makita battery powered tools Try putting the battery in the frezer overnight this remedy worked for me once with a Hitachi battery if not you would be cheeper buying a new drill rather than a new battery.
Dec 17, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Hi I have a makita drill 18 volt. I lent the drill to a friend and got it back not working properly. When I squeeze the button, the motor is running but the head of the drill is not turning and doesn't...
Check the speed control. There is a speed control usually from hi to low... sounds like it's in between speeds... try adjusting it back and forth...
It should go back into one gear and work fine.
Oct 06, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
206 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
