Question about Amana Quiet Zone 12M12TA Air Conditioner
Older Amana quiet zone
Model P12QZ22RC will not turn off when dial is in "off" position.
  • 3 Answers
Replace dial switch.
Posted on Jul 20, 2009
Fan continues to run in the off position?
The contacts in the switch are welded shut (if this is a portable unit). On a central system, the fan relay contacts are welded shut.
Oct 06, 2013 | Amana Quiet Zone 12M12TA Air Conditioner
Where do i find the model # on my a/c unit. It is 14 years old.
The model number should be inside the area on the front that the cold air comes out. If not it will be located on the front bottom edge. Hope this helps
Aug 18, 2010 | Amana Quiet Zone 12M12TA Air Conditioner
Water does not drain from my Amana quiet zone AC. It builds up inside, then causes rusty looking sedement to blow into my house. How/where is the water supposed to drain to the outside? Thank you, Bobbi
If this is a window unit it has to tilt a little to the back(outside) for the water to drain off the bottom back side. I am suspecting the unit is setting tilted toward the room a little. Look at that first. Hope I was of help to you!! Good luck!!
Nov 22, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Noisy Amana Quiet Zone air conditioner
The compressor sounds like the springs inside are bad. You can live with this are get the compresor eplaced if it is over five years old buy a new unit. Compressor will cost more than a new unit. Russ
Jul 18, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Amana Quiet Zone air conditioner 12m12ta
Try setting the Unit to run full out, set unit at 66* it maybe the lights flash to let you know the save ( power) is on ?. Otherwise look for the manual and troubleshooter page .
Jul 17, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Problems with Amana Quiet Zone 12M12TA, kicks off after short runtime, but other times runs for an hour cooling OK. Hear a clicking when it shuts down? Could not find a fuse ot relay?
Does it run longer when it's cooler outside like at night? If it is, it could be shutting down on high pressure or temperature caused by dirty condenser or you could have an overload in the compressor wire box that is weak or has a loose connection. Check the condensor coil to see if its dirty and see if it has an overload on the compressor.
Jul 11, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
My Amana LWA60AW washing machine won't agitate.
Some timer dials will not turn all the time they will sit for awhile then advance . If it don't move for a long time sounds like you have a bad timer motor.
Some motors can be replaced and some you have to replace the complete timer.
Jun 10, 2009 | Washing Machines
Stop button does not work on amanda quiet zone room air conditioner
hi there,
if the stop button doesn't work,it continously run you can shut off circuit breaker for emergency shuting off.if this a proramable a/c unplug your a/c and put it back wait for 15 minutes .and try to run if still doesn't work your holding relay is shorted from control panel,try to call a service technician to check the actual control panel defective.have a nice day,don;t forget to rate me,thank's a lot.
May 26, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Amana Quiet Zone 12M12TA Air Conditioner Logo
141 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
