Question about Microwave Ovens
Installing microwave How high do I need to be over the electric cooktop
  • William Miller
    William Miller May 11, 2010
    Your installation instructions / manual will show that info.
    If you don't have that, please reply back with your brand and model number so we can help you.
  • William Miller
    Your installation manual will specify this.
    If you don't have that, Please reply back with your brand and model number so we can help you.
  • Microwave Ovens Master
  • 9,174 Answers
Usually it's 29-31 inches, but please reply back with your brand and model number so we can help you.
Posted on Aug 21, 2008
SOURCE:
Should i keep the capacitor installed in the microwave before testing? Should i plug the microwave to electricity. Before testing?
please do not proceed. blown fuses is usually because of a bad door switch. there are three or more on every m/w. triple redundancy so high voltage radiation wont leak out and cook you instead of your food. or some times a shorted high voltage capacitor. ! it stores 2000 volts and can kill no joke. so discharge it with a plastic handle screwdrivers :) electricity "its SHOKING "
Jan 06, 2015 | In Microwave Ovens
I need to replace the cooktop light bulb-mmv5208ww
You should try to at least find the same wattage. The light bulbs are not dangerous safety hazards if they are made to fit microwaves.
Nov 07, 2013 | Maytag Appliances Over-the-Range Microwave...
Was removing a burned out bulb in my LG LMVM1935SB LG Microwave cooktop/oven. The bulb broke, and we had to finish getting the bulb out of the receptacle. The other light worked, but now apparently is...
When removing a bad bulb ALWAYS unplug the unit. If there is power going to the bulb and when you try to take the bad bulb out and the glass seperates from the bottom base the leads will short out and you will blow your main curcuit board. Then the entire board must be replaced. It will blow out a component on the board or blow a trace off of the back of the board. either way either baord repair or replacement will be needed. ALWAYS UNPLUG THE UNIT WHEN REPLACING A BULB!!!!
Sep 18, 2017 | LG LMVM2075 Microwave Oven
My whirlpool microwave model gh4184xsb needed a new cooktop light bulb so I removed the cover to replace it. I didn't unplug it (BAD!) and there were sparks and the microwave lost power. We repla
there are short. go to www.repairclinic.com for to get the parts.
2) test the switch door for short and replace see the diagram
3) test the high voltage capacitor+ high voltage diode
see the diagram
7_15_2012_12_42_08_pm.gif7_15_2012_12_42_27_pm.gif7_15_2012_12_42_40_pm.gif7_15_2012_12_43_03_pm.gif7_15_2012_12_43_25_pm.jpg
Jul 15, 2012 | Microwave Ovens
Microwave Cooktop / Night Light not working
I would check the door switches with a digital meter, set to ohms, disconnect one wire from switch and test for open and short by pressing door switch, if you hit one that tests the same when pressing and releasing, switch should be replaced.
Mar 06, 2012 | GE Microwave Ovens
Gas rings will not light because of no electric spark
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 20, 2011 | Baumatic Microwave Ovens
How do you UNinstall a GE Above the Cooktop MICROWAVE?
You can download GE owner's manuals and installation instructions here.
Feb 17, 2009 | GE JVM1440 Microwave Oven
I need to convert the updraft to a recirculation/filtering on a 1993 model 3vm140k003 GE spacemake microwave
If yours is not a GE, please reply back with your brand and model number so we can help you.
Aug 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replacement cooktop light bulbs
look inside for a removable panel for access to the lamps. consult your instruction manual.
Dec 28, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
105 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
