Question about Nintendo Super Paper Mario for Wii
Mimi's mansion freezing
I go and speak to the girl in mimi's mansion at the start and half way through the conversation it freezes and i have to turn the wii off by the plug and its not even pre-owned plz help me
  • stephaniebus Jan 02, 2009
    I have the same problem, mine freezes too. I have already taken one game back and had a replacement and it still happens. do we need to talk to her or can we move forward without.? or might there be an actual problem with the wii.?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 117 Answers
Is there a scratch? If there is, try this http://www.youtube.com/watch?v=Z537As9ehXo&feature=related
Hope it helped
Posted on Dec 31, 2008
How to freeze apricots
Before freezing, be sure you clean them thoroughly and avoid using any apricots that are damaged. Once apricots are washed and patted dry, cut them in half and remove the pits. Then slice them as you would slice peaches or any other similar fruit.
Boil a medium sized pot of water and dip the slices for about 30 seconds to prevent the skins from toughening, then place in strainer and run under cold water. From this point, freezing them may be done a few different ways, but the most important part is to be sure to include ascorbic acid to keep the apricots from turning brown.
One of the more common ways is to freeze them in a syrup. To make a simple syrup just add one cup of water with one cup of sugar to a pot. Heat and stir until all sugar dissolves. You will need about a half cup of syrup for each pint container you plan to fill with apricots. Then, add 1/8 teaspoon of the ascorbic acid to every cup of syrup.
Pour half of your syrup into a pint sized container you intend to freeze, then layer the apricot slices into the container, leaving about half an inch of space at the top, as the liquid will expand during the freezing process. After that, close the container, label it if preferred, and freeze it!
With this process, frozen apricots should keep for about 18 months if left in the freezer. Best of luck!
Jun 05, 2014 | Camping, Backpacking & Hiking
Why wont my Mitsubishi Colt start. It has gone into freeze mode. Can't turn key, start engine, change gear or turn wheel. Have tried with foot on the break but still no go?
have you had the OBD codes read as this should pinpoint the sensor(s) that are out or what else may be happening , i'm not espescially conversant with this condition , is there a section in the owners handbook ref "freeze mode " ?
May 02, 2014 | Mitsubishi Colt Cars & Trucks
2004 Chrysler Sebring will only heat up when in park, then it goes cold when I start to drive
Hello anonymous freezing girl.
The one thing that will do precisely what you describe is a
FAILING (or absent) thermostat...
Typically located at the engine end of your to
RADIATOR HOSE... b'twix $10 & $20 USD...
For MOST all engines to run efficiently... they must
reach & maintain an operating temperature of 180 °F
(Fahrenheit)... Temperatures vary by engine size...
2004 CHRYSLER SEBRING 3 0L V6 Thermostat RockAuto
Additional detail (small but terribly important)...
More Information for GATES 33878
Thermostat cover.. (looks like)
2004 CHRYSLER SEBRING 3 0L V6 Thermostat Housing Water Outlet RockAuto
More data
More Information for DORMAN 9025921
I am here daily...
merely comment me back: happy to discuss
Carnac the Magnificent
Nov 29, 2017 | Cars & Trucks
Intermatic PF 1102 digital timer with freeze control; Timer will switch from off to on to auto, but when switching to "on' the pump will not turn on. There is a "click" that indicates to...
The freeze control is wired parallel with timer, so both controls can turn Load ON-OFF.
So Load turns ON when either the freeze-control or the timer turns ON.
When both are ON, then Load will be ON.
Freeze control can be ON and timer OFF and Load is ON
Freeze control can be OFF and timer ON and Load is ON.
Only when both Freeze control and timer are OFF, will Load be OFF.
If pump is not turning ON below 32 (or the protection set point), then freeze control thermostat is suspect.
But you need to check if pump turns ON when timer turns ON.
If pump operates with timer, then freeze control is main suspect, unless there is a loose wire.
Open box and check for loose and burned connections.
If pump does not operate with either timer or freeze control, then check for loose wires and also check your circuit breaker and check that pump is operable.
To find replacement freeze control, Google search: Intermatic freeze protection thermostat
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 03, 2011 | Intermatic 24 Hour Electronic Timer
I am not sure on how to wire the freeze protection wires to the time clock. i know they must go to the load side of the clock for the main pump but will this reverse the power back into controls and short...
Here's a 240V diagram with clock timer and freeze control:
Add a comment if explanation does not fit your exact timer:
See image full size:
http://waterheatertimer.org/images/Freeze-protection-500.jpg
Here's how freeze control works:
Freeze control is like regular timer, except it turns ON by thermostat instead of time-clock
Freeze control turns ON pump whenever thermostat kicks on.
Both clock-timer and freeze-control are wired to pump in 'parallel' so to speak.
Think of it as having two controls wired to same pump...
Both controls can turn pump ON-OFF.
If one turns ON, and other is OFF ... then pump is ON.
If both are ON, then pump is ON ... and electricity just flows around on extra wires.
If both are OFF, then pump is OFF.
Say it's below freezing all day.
Freeze control circuit is ON all day ... pump is ON all day
Clock timer turns ON > but circuit is already ON, so timer just opens more wires for electricity to flow around on.
When clock timer turns OFF > freeze circuit is still ON because it's below freezing ... pump is still ON.
240V wiring:
Power leads coming from circuit breaker go to terminals 1&3 on clock-timer
Same power leads connect to freeze-control-black and freeze-control-red.
Or connect freeze-control-black and freeze-control-red to terminals 1&3
This action puts power to clock and power to thermostat
Pump wires connect to terminals 2&4
Same pump wires also connect to freeze-control-blue and freeze-control-yellow.
Or connect freeze-control-blue and freeze-control-yellow to terminals 2&4
This action connects pump to both freeze-control and timer.
When either clock-timer or freeze-control turn ON, then pump turns ON.
Nov 15, 2010 | Intermatic Timer PF1222TB Multi Circuit...
No disk & freezing
possible dirty or defective lens
May 31, 2010 | Oppo Digital OPDV971H DVD Player
Condensor unit freezes up.What would be the best way to cean unit without taking it out
unfortianatly without removing it your really not doing yourself any favors, it may stop freezing up for a short time but its only a half @#* fix. i am also assuming your speaking of the evaporator not the condensor, the condensor is outside the evap is inside
Nov 04, 2009 | Ruud Central System Air Conditioner
Freeze when it turn on. Start up bar pass half way
ur fone probably had contact with water take it to the condore shop
Jul 09, 2009 | Sony Ericsson G900 Smartphone
Ps3 freezes and doesn't reconise game
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up..
Apr 04, 2009 | Sony Playstation 3 (PS3) Console
Nintendo Super Paper Mario for Wii Logo
106 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
