Sharp Aquos model LC-37D4UJ; no audio from speakers or audio output jacks
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
SOURCE: variable audio out has no output
I turned off the internal speakers in the TV and the external speakers then worked.
Posted on Feb 26, 2008
  • 45 Answers
SOURCE: SHARP AQUOS LC-26P70E - Clock
Most TV's don't change with daylight savings time, since they do not operate with a date, just time. You will need to change it via the remote.
Good luck
Posted on Mar 31, 2008
Russmann
  • 203 Answers
SOURCE: Sharp Aquos LC-20B6U-S TV NOW
This can be caused by many different things. Check power supply fuses. If ok suspect inverter board which drives screen. Check for bulging capacitors and open transformers or just find replacement cost using numbers on board. That may fixya.
Posted on May 29, 2008
  • 1894 Answers
SOURCE: Sharp Aquos LC-30hv4u
this looks like a power problem sir.
do you use a surge protector?
Posted on Jul 14, 2008
My sharp aquos tv LC-60LE632U has picture but no sound, What can be done?
Check the audio 'output select' under the Systems Settings menus. The output may be set to 'variable'. Set it to 'fixed' so that the audio runs through the speakers.
Oct 12, 2014 | Sharp AQUOS LC-60LE632U 60" LED TV...
Sound
Your TV has both analog and digital sound output jacks. You will need to connect to an audio amplifier/speaker system that can use either of these types of audio signals. Consult your TV user manual for more info.
Mar 22, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Can i connect speakers directly to Audio R L output on Sharp Aquos LC?
NO. The outputs are at line level. You'd need an amplifier between them.
Oct 02, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No sound from t.v. speakers
check with Sharp for recall. I already saw that on a other model of Sharp and it was the heat sink compound on audio output ic. For that model they had a modification kit and procedure to cure it.
hope will help
Apr 29, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My sharp aquos 32" has no sound. it just stop working
Have you gone into the menu to see if the internal speakers were accidently shut off (most LCDs have this feature)Try plugging a speaker into the audio output to see if it is producing sound that way. If so you may have a bad speaker.
Aug 14, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How do you connect external speakers. Which
use hte head phone output as the speakers have that jack plug
Jun 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Hook up speakers to 32 inch lcd hdtv
"Line" level audio output is available at the audio output phono jacks at the top of the rear panel, but not speaker-level output. So, you'll need an amplifier to use in conjunction with your external speakers. (An alternative would be "powered" or "amplified" speakers that have their own amplifier, but often are less satisfactory acoustically). You don't necessarily need to get a full-fledged "receiver" with multiple in's & out's... I simply used an inexpensive stereo amplifier.
Connect the "Audio L - R" jacks on the rear of the set to the "line" or "aux" inputs on your chosen amplifier and speakers. If you go into the set's Menu - Option - Output Select and set it to "Variable", the internal speakers will be disabled, and you can control the volume (and muting) of the audio sent to the amplifier, and still have "armchair" control of the volume as before... but now with better stereo!
May 16, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No sound from audio output This set is new.
The speakers need some kind of amplification, if you have something like a set of computer speakers connected and they are not powered they won't work, try connecting them to the headphone jack.
Let me know the set up, what kind of speakers, audio settings from the tv menu.
lone99star
Jan 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
326 people viewed this question
Top Televison & Video Experts
Electro Med Services...
