Question about Toshiba 55H70 55" Rear Projection Television
No video or audio
My TV just died. The image started going out until it was gone. I unpluged the tv but nothing happened. The light by the power button blinks.
  • mrsboz Aug 29, 2008
    Same problem here...power light just blinks but no audio or video.
  • 2,071 Answers
Trouble maybe one of the control IC there is defected or cold solder of joint of the parts causing intermittent problem. Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If i have helped,please click fixya.It is the only way i get paid for my work...
Hope this may help you;
DON'T FORGET TO RATE;
Regards,
VOTIT
Posted on Sep 06, 2008
Turn on power the power light lights up for few seconds and starts blinking?
The first step in troubleshooting this would be to perform a reset on the TV. You can do this by unplugging it from power for a couple of hours. Once you've done this, plug it back in and power it on and see if any issues persist.
If there is audio but no video you may be experiencing processor failure and some additional troubleshooting is going to be needed.
If there's no video or audio, chances are something caused the TV to short out somewhere. Most of the time the culprit is the actual power supply itself. The repairs on these aren't too difficult or pricey and if the TV is still under warranty you should be able to get it fixed for free.
Jun 27, 2011 | JVC LT-32P679 32 in. LCD TV
Red light on front, no audio,video, have unpluged and left unplugged for days , plug it back in and get the same thing
the red light is on because part of the power supply is still alive(usually +5v source), but there could be a problem after the ps that might be causing the tv to go into shut down. that might be why there is nothing happening when power is pressed.
Aug 07, 2009 | Hitachi 43FDX20B 43" Rear Projection...
Nakamichi TA2A gone dead
This unit needs an overhaul. There are defective capacitors and poor solder connections that need repair. I have done a number of these and the repair is straightforward.
Dan
Jul 22, 2009 | Nakamichi Audio Players & Recorders
Toshiba tz43v61 TV just died. No red light.
does it have a power strip on the tv stand? if so plug the tv into a wall socket.my power strip went bad and the reset button did not work
Jul 17, 2009 | Toshiba TZ43V61 43" Rear Projection...
I initially turned on ps3 system on tv. image
Turn off the system, Then when its in standby mode when the red light is on, press and hold the button to turn it on, Wait untill you hear 3 beeps then let go if the system turns off try it again its a master reset then just restore factory settings
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
TV won't turn on even though it starts green, then goes off
Although my tv still does the "turn green and turn off" thing, I simply unplugged and repluggd the tv. After I did that, I pushed the "ON" button on the tv itself, unplugging and replugging the tv until it finally came on. I think the "instant warm-up" switch is going out.
Feb 18, 2009 | iLO 3200 32 in. LCD Television
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
Sony Wega TV
9 times flashing light shows error in Audio Amp section. Please check Audio Amp IC and related parts including +&-19 volts supply line to this section.
Though its technical reply yet I hope it help you.
Aug 07, 2008 | Televison & Video
The Sound is Gone.
Hi....
The circuits that routes all the audio signals thru the amp has either died OR the power supply that runs that circuit has died.
Estimate to fix : $75-125
Apr 22, 2007 | Pioneer VSX-D711 Receiver
Toshiba 55H70 55" Rear Projection Television Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
