Sorry to hear about your sons bike have been messed up. First you have to check out if the brake works. Pull it with your fingers (brake itself, where the cable is attached). If it squeezes and springs back, there is no probs. Then loosen the cable and check if the brake lever works (use it as if you are braking). It should go down and spring back itself. If it does, there is no probs. In that case all you have to do is to loosen the cable at the brake itself and then re-fit it by pulling the cable with pliers and securing it with the appropriate screw.
