Question about Symphonic WF104
Dual layer disc problem
Will the WF104 play dual layer disc and if so do I need to do anything special?
  • 981 Answers
Did you glance in the manual to see what types of DVD it would play (typ. DVD-9, DVD-4, etc.) and try it?  This site can't prevent you reading appropriate manuals, you know.
Posted on Aug 17, 2008
Whats a dual layer disc mean then?
A dual layer disc is a DVD which is able to hold double the info.( http://en.wikipedia.org/wiki/DVD#Dual-layer_recording )
Dual-layer recording (sometimes also known as double-layer recording) allows DVD-R and DVD+R discs to store significantly more data-up to 8.54 gigabytes per disc, compared with 4.7 gigabytes for single-layer discs. Along with this, DVD-DLs have slower write speeds as compared to ordinary DVDs and when played on a DVD player a slight transition can sometimes be seen between the layers. DVD-R DL was developed for the DVD Forum by Pioneer Corporation; DVD+R DL was developed for the DVD+RW Alliance by Philips and Mitsubishi Kagaku Media (MKM).[23]
A dual-layer disc differs from its usual DVD counterpart by employing a second physical layer within the disc itself. The drive with dual-layer capability accesses the second layer by shining the laser through the first semitransparent layer. In some DVD players, the layer change can exhibit a noticeable pause, up to several seconds.[24] This caused some viewers to worry that their dual-layer discs were damaged or defective, with the end result that studios began listing a standard message explaining the dual-layer pausing effect on all dual-layer disc packaging.
DVD recordable discs supporting this technology are backward-compatible with some existing DVD players and DVD-ROM drives.[23] Many current DVD recorders support dual-layer technology, and the price is now comparable to that of single-layer drives, although the blank media remain more expensive. The recording speeds reached by dual-layer media are still well below those of single-layer media.
There are two modes for dual-layer orientation. With Parallel Track Path (PTP), used on DVD-ROM, both layers start at the inside diameter (ID) and end at the outside diameter (OD) with the lead-out. With Opposite Track Path (OTP), used on many Digital Video Discs, the lower layer starts at the ID and the upper layer starts at the OD, where the other layer ends; they share one lead-in and one lead-out.
Jun 16, 2011 | Nintendo Wii Console
Jensen vm 9410
some of the newer dvd's are made double layer and recently they've been working on triple layer dvd's. basically a single layer dvd holds 5gb of information, a dual can hold 10gb and a triple can hold 15gb (those are approximates). by making it more layers, they can put the fullscreen and the widescreen edition on the same movie disc. some of the 'lower end' dvd players don't have the capabilities to play these dual or triple layer discs.
Sep 21, 2009 | Jensen VM9410 Car DVD Player
Hi, I bought Bose 3 2 1 SERIES 11 Home system. but i cannot play wedding dvds on my system. All hollywood movies plays ok. I tried Verbatim DVD R & DVD-R there is no picture but the sound is there....
I would say that as with many manufacturers, the Bose 3-2-1 is meant to play Dual Layer DVDs. Since they hold data on 2 separate layers of the disc, these hold twice the amount of data than the Dvd+r or -r that you're using. When the Bose system tries to read the 2 layers and only finds one it, will not recognize the dvd. If you don't have a Dual-Layer burner and Dual Layer discs to burn to, you should upgrade your burning equipment. They're not that expensive these days. Cheers!
Nov 07, 2008 | Televison & Video
DVD BURNING
yes there is, there is plenty of software that will actually make any size move fit on a regular 4.7gb dvd, my definate favorite is CloneDvd2, also nero will, hope this helps and anything else i can help you with i am happy to help, also the most likely reason your dvd wont play the dual layer disc is that it doesn't support dual layer.
Sep 08, 2008 | Computers & Internet
Get photos and videos onto the disk
You should only have to finalize the disc and then it will work in your PC, you need DVD playback software to play it. If its a dual layer disc your, DVD drive in your pc needs to be able to play dual layer.
Enjoy,
Lee
Jun 12, 2008 | Canon DC210 DVD Camcorder
Finalizing both sides
A Dual Layered (DVD-R DL) disc has two recording layers on the same side of the disc. No recording is made on the 'other' side of the disc.
Finalising the disc will finalise both layers. Most probably your computer DVD drive cannot read both layers of the DVD-R DL disc. DVD-R DL discs can only be played back on DVD devices that are compatible with dual layered discs.
Check your computer DVD drive spec to see whether it can read DL discs.
Mar 19, 2008 | Canon DC210 DVD Camcorder
Will not burn
try to clean the lense with a special brush cd.ussualy this works
bye
Feb 03, 2008 | LG GSA-E10L (8801031212552) DVD±RW Dual...
DVD formats burned by LG GSA 4163B
yes... but you need to have a good ammount of RAM memory and Disk drive space to achieve that since dual layer disc are up to 8 gigs..
Jan 08, 2008 | LG GSA 4163B DVD±RW Dual Layer Burner
Player freezes on Dual-Layer DVD+R's... any ideas?
Its probably compabitilities issues. Try -rs. There a lot better since they are more known type and technology. the difference is +r have more editing features but in your case it doesn't matter because your just copying.
Dec 31, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Symphonic WF104 Logo
73 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
