Question about Philips 9P5544C 55" Rear Projection Television
TV repair I bought a big screen from a friend of mine and there is a problem with the picture, there seems to be a lot of green in the pic, especially around white colored object, so it's makes for poor picture, I was wondering how to fix it and how much would it cost? It's a Phillips Magnovox 64" rear projection television, Thanks
  • unclebubba Sep 08, 2008
    My TV comes in blurry and there seems to be alot of green and blue
  • Philips Master
  • 8,617 Answers
You need to replace the coolant in the CRTs ( picture Tubes) you can get the repair kit at the following link which contains all the coolanr and the instruction CD with the step by step instructions with pictures so you can easially do it yourself. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 17, 2008
Turns on for 30 sec then goes bright blue and goes back into standby. turn back on it does it agian
This is blue CRT problem in tv as it is rear projection tv that has three CRTs red-green-blue inside to project color picture on front screen.
Blue CRT (tube) will be replaced to fix the issue and it is job of Pro because lots of adjustments are required after replacement of tube.
Local tv repair shop will help you for that.
Thanks
Oct 02, 2010 | Sony KP-51WS500 51" Rear Projection...
Magnavox big screen has dull picture and colors are not clear. Cloudy picture and has a green film of color over screen. this ia a 64inch big screen. What can
This is especially common with Phillips/Magnavox - A foggy image usually suggests that the coolant in the picture tube(s) (1or all 3) has become discolored and needs to be replaced. The only way to check this is to look directly into the crt faces (disassembly required) to see the condition of the fluid (coolant).
It's a relatively big job that shops charge between $300-400 - Get an estimate. See link for Kit
http://www.tvrepairworld.com/crt_coolant
Nov 06, 2009 | Philips Magnavox 27MS343S 27" TV
Sony KDS R50XBR1 TV, LIME GREEN PIC
if all sources and hdmi cable are good--you need the hdmi input board--dont know sonys letter designation
Jul 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
A lot of red in pic no matter what we do and tint dose not change anything
As is typical with all Philips projection sets the cooling fluid has become contaminated in the blue and green picture tube assemblies. The red is almost never affected with this as whatever bacterial growth is discoloring the fluid in the blue and green tubes can't seem to survive in red light. The blue and green light is shining up through muddly cooling fluid and that is why the red is predominating. A reputable tv repair shop can pull the tube assemblies and dismantle them and clean and reassemble and refill and do all the necessary adjustments for around $300 to $400.
May 26, 2009 | Philips Televison & Video
Sharp D64 37" issue (Power+OPC light flash and won't turn on)
I'm going to guess your friend's model is LC-37D64U. ( 37" screen; D64 series)
It's sounding like a power supply problem for the LCD screen. It's somewhat common problem for big LCD screens. But, too early for your friend to be having this problem with the TV.
I would have your friend use the warranty at this point. Last thing you want to do is void the warranty by opening up the TV.
I would first try leaving the TV unplugged for 30 mins so it can reset. Then, try turning it ON again.
If that doesn't work, it warranty time.
If your friend just bought it, have them exchange the TV for another one. I wouldn't want a TV that has problems that just came out of the box. The Sharp TV only has a 1 year warranty. Upgrade warranty life if possible. A repair for a problem like this would cost about $100 for someone to look at it; and $200 to $400 for the part at a TV repair shop.
May 12, 2009 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Screen size
YOU MUST GO INTO YOUR PS3 VIDEO SETTINGS MENU AND SET YOUR HDMI TO 1080P AND YOUR PICTURE SHOULD BE OK
Nov 02, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Picture too big for screen
if anyone has this p61960 television that does not work anymore, I am looking for parts for mine and would buy, please let me know, thanks
Oct 14, 2007 | RCA P61960 61" Rear Projection Television
Pioneer rear projection 51inch tv
moving big screens around may throw off the convergence, look to see if you have red,blue or green or all.. ghosts or edges in the picture. you will need a tech manual ..not owners manual to fix it, I would call a local tech and hear what he thinks for just a service charge. good luck
Sep 01, 2007 | Televison & Video
Picture screen
This is an ongoing screen defact - Contact Kodak for a repair quote.e
Jul 17, 2007 | Kodak EasyShare DX7630 Digital Camera
Polaroid LCD only shows green verticle lines?
your picture tube is not blown you are having problem in the color circuit there is an ic that controls that circuit,the tv is also having a vertical problem an ic also controls that circuit you will have to call a tech to repair your tv good luck
Apr 27, 2007 | Polaroid FLM-2011 Television
Philips 9P5544C 55" Rear Projection Television Logo
89 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
