We can't access the WEP address. - Computers & Internet
    Sergeant:
  • 395 Answers
Use 64bit WEP key.
Set key as 10 hex digits on router and PC
e.g. 1A B2 C3 D4 E5
don't generate a key from a password - use hex digits in both
Posted on Aug 17, 2008
6ya staff
SOURCE:
Where is wep key location
WEP key is in your router's configuration settings.
in windows open a command prompt (search for "cmd" from the start menu)
in command prompt type "ipconfig"
Look for "default gateway" and remember the ip address listed for it
in your browser (internet explorer, firefox, chrome) type the ip address from the default gateway into the address bar. probably something like 192.168.0.1
once you access the router settings, the WEP key is under the WIRELESS section, called security.
Aug 12, 2014 | Linksys Computers & Internet
Cant find wep key
You will need to access the router (via its local web address using a suitable web browser) Once you have provided the login information, surf to the wireless security section and either document the WEP key (if not encrypted) or change it. Understand that changing the WEP key will invalidate any else's access, so be sure to share the change. The WEP key may have to be done in HEX, meaning that it must be done with the numerals 0-9 and ONLY the letters A-F. The ket must also be a specific length, usually 13 or 26 characters depending on the requirements of the router.
Aug 11, 2011 | NetGear WGR614 Wireless Router
How do i find my wep key
for finding wep key you willhave to access the firmpage of router then under advance section where you have entered wep key uncheck the option hide wep key it will display the key to you or you can also enter a new key if you want,.
in order to access the fism ware of the router please type 192.168.1.1 in the address bar it will display the firm page of the router.
Sep 05, 2010 | Computers & Internet
About 1 yr ago, I allowed my neighbor to connect w/my linksys router. Now, our IPS has instituted a "fair access policy," and I need to remove my neighbor from my network. Can u tell me how to do this?
Change the WEp/WPA security key and don't let eh neighbor have it. That will kick him out of the router. You could also go into the router table and look at the MAC address associated with his IP and block that IP address and that will kick him out as well. If you block his IP and your router is set for DHCP he can log out and log back in and get a new IP address. Blocking by MAC address and using WEP/WPA security key is the best way to block unauthorized access to your router. The WEP/WPA key will be located on the page that router Wireless Security settings are on when you access your router.
Aug 08, 2010 | Linksys Computers & Internet
How do i find my Wep key for my netgear router
you have to access the GUI of your router. if you dont know the ip address. go to command prompt and type in ipconfig. look for the gateway ip address and type it directly to your I.E address bar. once you are inside the router interface, ussually WEP key is under wireleess security. go over there and check your WEP key. you can also change the WEP key.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 03, 2010 | Computers & Internet
Error code 51330 on the wii.it will not except my
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
Need further troubleshooting? Go straight to Nintendo's website at:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Nov 19, 2009 | Nintendo Wii Console
Cannot connect to internet error code 51330 is showing
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Need more info? Check Nintendo's website at:
Wep address
WEP address is your security key to get on the wireless network. New access point usually do not have one assigned. You need to get into the router and enter it in, like a password. If you haven't setup the network, then someone else did and you need to get the WEP key from that person. If you can get it, then you could reset the router to factory defaults by pressing and holding the button in the back of the router for 30 seconds. Let the router reboot and look for a wireless network called "LINKSYS" or "DLINK" or something like that. You should be able to connect without entering a WEP key. If your computer asks you for one then leave it blank or look in the manual for the default WEP key.
Mar 28, 2009 | Linksys Wireless-G WRT54G Router
How do I get a wep key and what is it?
A wep key is a type of internet security (mostly used on routers) to prevent any unauthorized access to their internet connection. And to get a key, go to the router you wanted to connect to and ask for the wep key and to add you to their mac address book, or if you own one, go to the txt. document that was downloaded on your desktop and look at where it says network security key, and if your router has a mac address filter, add your ds's mac address to the mack address book on your router. then connect and type the key.
Nov 11, 2008 | Nintendo DS Lite Console
Open Questions:
Computers & Internet Logo
29 people viewed this question
Ekse
Marvin
Marvin
