Question about IBM ThinkPad A21m 2628 Notebook
Won't start up
IBM A21...will not start up...LED's flash, internal fan comes on, then everything goes off. There is no other noise or lighting up of the screen. Whole process takes less than five seconds. REPEAT...same results.
  • IBM Master
  • 5,568 Answers
Please check this thread, it may be one possible answer to your problem-
http://www.fixya.com/support/t944088-ibm_thinkpad_a22m_2628_power_problem
Posted on Aug 20, 2008
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
My screen dont light on my aspire 7250
I have just fixed an Aspire 7250 with following symptoms: Only blue Power LED or battery charge LED come on, fan spins, no backlight, no video either on internal screen or VGA output.
Problem solved desolderig BIOS flash chip (W25Q16) and flashing BIOS 1.10 with an universal programmer.
Aug 06, 2012 | Acer Computers & Internet
Tecra r840 wont start (Won't even go to boot menu)
Try reseating the RAM module/s. If it still does not boot up then then RAM could be faulty, remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Mar 12, 2012 | Toshiba Tecra Computers & Internet
Hi have an IBM A21 it will not power up, when pressing the start button the green battery lamp goes off and there is a small flash in the hardisk lamp, and I can here a small "click" the green battery lamp...
If it's not your battery, then it's possible that your motherboard has died (if it was the HD you would at least get the BIOS screen before it stopped). I suggest you take it in to a qualified repair center & ask them to give you an estimate of the repair cost. The A21 is an older model & you may likely be better off investing in a new laptop than fixing the old. Make sure you keep the hard-drive though as you will likely want to get your data from it!
Apr 24, 2010 | IBM ThinkPad A21m 2628 Notebook
Not coming on-tries 9 times Then stops
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic chargesaccumulating on capacitors, or because of a wrong voltage read by themain chip on your monitor controller board. this started the protectioncircuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jul 02, 2009 | Televison & Video
IBM thinkpad A21 won't start up
1# remove the battery from the thinkpad and ac adapter.
2# hold the power button for 40 seconds.
3# plug in the ac adapter and turn on the botton.
4# see it for works what trying to do to thinkpad is recyle the power .
give it a try and see if it work if it doesnt let me know
Nass
Apr 14, 2009 | IBM ThinkPad T21 Notebook
When i switch on the my thinkpad it starts to boot up then the screen goes blank the battery light goes orange and and flashes and it makes a cranking noise.
Is the Battery making the cranking noise? If so the battery is telling you the battery is dying. I have a IBM ThinkPad 380Z and when on the charger it makes a beeeeep noise and goes off and on for almost the entire day and then stops and keeps a solid orange battery light on.
Try booting without battery
Feb 23, 2009 | IBM ThinkPad T40 2373 Notebook
Asking
Let me start by saying that there are alot supossed or claim to fix fixes for this on the internet. I've tried them all, and the only two fixes for this are replacing the motherboard or replacing the malfunctioning chip on the motherboard that has caused this. The simplest, easiest, and most of the time cheapest sure way to fix this is to replace the motherboard. The other way is to track down the failed chip and have a new on soldiered to the board. Most people can't do this on their own, and if you can find a shop that will do it, they will charge in the hundreds of dollars. There are several A21 motherboards on Ebay for lees than $50, most have the base that is intact, so all you will have to do is swap out the drives, screen, memory, covers, keyboard, and screen. Then tou're up and running again. Here's a couple of links to help. The first is Ebay's A21 motherboard listings, and the second is various manuals for the A21 to help you swap everything out. Doing it yourself isn't that hard and will save you quite a bit of money.
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=+IBM+ThinkPad+A21m++motherboard&category0=
http://www-307.ibm.com/pc/support/site.wss/product.do?template=/product.do?template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&sitestyle=lenovo&brandind=10&familyind=50281&machineind=78390&modelind=0&partnumberind=0&subcategoryind=0&doctypeind=8&doccategoryind=0&operatingsystemind=49979&validate=true
Jul 28, 2008 | IBM ThinkPad A21m 2628 Notebook
My ibm thinkpad booting and hanging fault
Try this... to see if your video card is bad...
Connect your laptop to an external monitor and press the Function key plus F5 on the laptop... if your OS shows up on the monitor screen, then you have a bad video card...
If its not the video, Bad Ram might be the cause.
And worst case.. Need Motherboard replaced...
Jun 09, 2008 | IBM ThinkPad T42 Notebook
IBM ThinkPad A21m 2628 Notebook Logo
130 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
