Question about Intel Motherboard
Unable to install game
Hello Sir,
Recently I purchased new graphic card of Nvidia , 8500. But While I m trying to install" price of persia ", installing almost going to finish and msg will be displayed like that " Manually Process Killed ".
Although short cut on desktop has been created .But when i m using that shortcut to play game same msg will appeared " Manually Process Killed ".
This is happening for both games of price of persia "Warior and Sands of Time".
My PC Config:
OS:Win XP professional + SP2
Processor:Dual Core
Motherboard:Intel d945GCCR
Graphic Card: Nvidia 8500( 512MB),
RAM:DDR2 1 GB
Pls help me what to do run game.
Thanks in advance
  • 50 Answers
Ur config looks gorgeous and fit to run the game. Maybe its the problem of the DVD's. Check for any scratches....try the same dvd's on a friends system if possible to see if they work and tell me..............
and next time add a comment here itself....
don't keep opening new problems...
i am having trouble finding them.
Good Luck
Posted on Aug 18, 2008
Win xp will not shutdown installed new Nvidia Geforce 9300GS PCI
hello sir
u need to do two things
*deactivate the onboard vga adapter from the bios
*and install the official lates driver for ur card
if u can't find it tell me wht's ur operating system i will provide u a download link
Feb 13, 2013 | Nvidia Geforce 9300GS, PCI Express Video...
My gf8500gt pcie 512mb ddr2 is not working properly when i put a game on the system freeze i removed the pcie and now the pc is running ok but unable to play games would you say the pcie card has aproblem
It might be a case of simply downloading and installing the latest drivers for your graphics card. Go to www.nvidia.com and click their download drivers button. Then select your card form the list and download and install the latest drivers. Heat could also be an issue. Ensure that the cooler is clean of dust and that the fan is running smoothly. Install additional fans in your chassis if possible, as graphics cards tend to give off the most heat in a computer system. Also clean the gold fingered connectors of the graphics card with tissue paper. Set the graphics of the game down a bit, it is possible that the card is not able to cope with the load it is set to run at. Reducing the graphics may help.
Take care!
damnor01
Oct 01, 2011 | XFX NVIDIA GeForce 8500 Graphic Card
I have purchased a asus p5g41c-mlx motherboard on jauary 2011 .but after 2 month its grahpics not work properly ,it is flickering ,i have using window xp. i have uninstal the grahpics and reinstal it but...
Hello there,
Here is *********** boards VGA details.
Integrated Intel GMA X4500 graphics Maximum shared memory of 1GB
Supports RGB with max. resolution 2048 x 1536 (@75Hz)
Supports Microsoft® DirectX® 10
Here are the system requirements of the games you are currently playing with problem.
NFS Most Wanted- It should run with no problems just avoid high detail settings.
Minimum: 32MB or more, ATI 7500 or greater; ATI Radeon Xpress 200; NVIDIA GeForce2 MX/GTS or greater Recomended: NVidia 5900 or ATi 9800 with 256mb of video memory
Prince of Persia Two Thrones
Minimum: 64MB Recomended: better than recommended in NFS Most Wanted
COD Black Ops
Minimum: Shader 3.0, 256MB GeForce 8600GT/ ATI X1950 Pro or better. Recommended Nvidia: GT 240 or higher Recommends Ati: HD 4670 512MB or higher Minimum Memory: 2GB
Some games have hardware validation test if your unit fails to the requirements you cannot install the game. try to download this BurnIn. Select the 32bit Standard edition. install the utility and stress your x4500 graphics. Sir you did not post your Processor and Memory. The x4500 graphics will use 128MB of your ram, If you are using 1GB or 1024MB - 128MB = 896MB. 2GB or 2048MB - 128MB = 1920MB. For Memory system requirements your system failed and the main problem is your video card.
Hopefully this helps.
Thank you for using FixYa.
Jul 22, 2011 | ASUS Computers & Internet
Dear sir, i installed the prince of persia sands of time. but it says the game ended unexpectedly. so i just want that how to work the game.
try reinstalling the game ..... hope it works
and also check whether u r machine meets the minimum software requirements
specially u r graphic card ... .
Jul 13, 2011 | Ubi Soft Prince Of Persia: The Sands Of...
I am using nvidia gforce graphics card.......but prince of persia sands of time video not goood.what should i do??????
Hello :
Try this please :
Uninstall the game from your computer and reboot your system , then install it again and reboot system again . That could help fixing the problem.
You also can check system for viruses or malware . Try also check the registry for errors .
I hope this will help .
Please rate !
Jun 03, 2010 | Ubi Soft Prince Of Persia: The Sands Of...
Gforce 8500 not responding in middle of some games
try a new driver or new gta patch. Really though, you need a new graphics card. the 8500 is a budget low end card. get a Nvidia 9800gtx/ gtx 260 or Ati 4850/4870 to game! Make sure you have a good dual core cpu also.
Apr 06, 2009 | ATI Diamond 4850PE3512 RADEON PCIE, GDDR3...
Need advise for upgrating graphics card
GET THE NVIDIA G FORCE 8400 GT IT IS THE NEWEST CARD AND IT WILL RUN EVERYTHING YOU HAVE.
Mar 27, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Geforce 8500 GT Causes "Snowy" screen
You have Vista 64 bit right? I looked and the newest nvidia driver is 182.08 located here:
http://www.nvidia.com/object/winvista_x64_182.08_whql.html
1. Download this driver.
2. Go to the Control Panel, Programs and uninstall the current nvidia driver.
3. Shut down computer.
4. Remove video card and re-install it.
5. Start computer and install new nvidia driver.
Mar 11, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Nvidia 8500 512mb card new drivers i want upgrad
http://www.xfxforce.com/en-us/Help/Support.aspx
This link will take you the support web page. All you have to do is register then you can download the driver for free.
Feb 22, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Intel Motherboard Logo
51 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
