Question about Kenmore Elite 45986 Front Load Washer
Front loader f02 code
Kenmore front load elite 3t i had a teck out to repair broken shocks but now i keep getting f2 code or sud when it is inlast 3 min of rinse and gets code and that is it. I have check drain for clogs and nothing in punmp any other suggestions?
  • 5,911 Answers
Check the entire length of the drain hose as well. This is from the bottom of the wash tub, to where it connects to the drain pump, to where it exits the washer to the standpipe. The two error codes can be directly related to each other. "F02" usually indicates a clog or failure of the drainage system. "Sud" can be caused from using too much, or improper detergent. It can also be caused when the drain pump is not functioning properly and is pumping air. If you have tried the "Rinse & Spin" option to clear the error, and you have verified all of your drainage system and still have a problem. It is recommended that you replace the drain pump. It may be running, but the impeller may be damaged and it is not pumping water properly. The following links may be of assistance to you:
http://www.fixya.com/support/r629564-suds_error_whirlpool_kenmore_front
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
You may have already viewed this information, but posted it just in case you may have overlooked anything.
If you determine you have a failed pump and which to replace it yourself, the following link explains how:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
If you require addtional assistance, please let me know. I hope you find this information helpful.
Posted on Aug 17, 2008
My Kenmore Elite front loader keeps on showing the same problems
Cut down on your soap i only use very little soap and it works great.No more SUD code
Jul 02, 2014 | Kenmore Elite 45986 Front Load Washer
What does the trouble code f2 mean for the kenmore elite 4t washing machine?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 22, 2011 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite he 3 front load washer...im getting f error 02. it runs fine until the end of the cycle will not drain or spin.
Kevin
May 22, 2011 | Kenmore Elite 45986 Front Load Washer
My kenmore elite mod 42832 has a error code f2 does not drain or spin
Hi
Error F2 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 23, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Jun 06, 2010 | Kenmore 44932 Front Load Washer
My Kenmore Elite HE 3t keeps flashin the F02 error code i cleaned the hose that dispenses the water and the connection to the hose but the problem continues can you help me
u might have a drain problem u need to take the front panel off at the bottom there are 3 t20 torque bits take them off and the water pump should be in front or to the right side theres a filter for the pump u need to take that of and see if there is any objects in the filter if so clean it out.then check your drain two if this does not work u might need to replace the pump good luck
Feb 15, 2010 | Kenmore Elite 45986 Front Load Washer
Won't drain
"F02" is a Long Drain error code. This indicates that you have an obstruction in the drainage system, as you well know by now. The following link explains:
I enclosed this information just in case you may have missed somethins. Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail. Also, check the connector plug on the pump to ensure it is making contact. It can come loose from vibration.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. In addition, the "SUD" error can occur in conjunction with a drain pump failure as this error occurs when too much air is sensed in the drainage system.
Oct 02, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 3t
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 11, 2009 | Kenmore Elite 45986 Front Load Washer
*&^% screws!!!
F2 = Long Drain. Most common cause is something (or lots of things) stuck in the drain pump. There are screws at the bottom of the front panel that can be removed to check it out. If the screws look like stars they are Torx head screws, get driver from most home centers.
Go here for Kenmore HE3 washer parts:
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts
www.RepairClinic.com
Feb 03, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
117 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
