Question about Thetford Refrigerators
We have a Thetford N80 fridge in the caravn which will not light on gas. It clicks but no flame appears.
  • 51 Answers
Try manually lighting the pilot when it is clicking. If it lights you need a new thermo couple let us know what you find out from this step
Posted on Sep 08, 2008
Today i found my thetford fridge in c/van not working on 240 power so i turned it on to gas and it workes. Any idea what might be the problem?
the fridge works by heating crystals that creates a gas that is the refrigeration
if it works on gas then the system is good and indicates that the 240 volt heating element is not working
find a caravan repair center and have it checked out
Nov 25, 2016 | Thetford Refrigerators
I have a thetford N80 fridge fitted in my motorhome that pops the rcd until I cool it down using gas
it is drawing too much current and is a fire risk
there is a live wire touching the metal frame or the motor has locked up.
the rcd is saving you from having a fire or being electrocuted
can you find a local dealer who can diagnose/repair?
Sep 27, 2013 | Thetford Porta Potti 550P MSD
Norcold fridge berps and display says No flame
check for a gas shut off inside the fridge cabinet as well. You may have to bleed all the air out of the lines before the fridge will get gas. either keep trying or run stove burners to make sure gas is working. Also look for debris inside the burn chamber near the thermocouple/pilot light.
I had rust fall from the exhaust tube and block the burner area. Cleaned it up and it works fine now.
Mar 25, 2013 | Thetford Norcold DE0051 Refrigerator
I have a thetford N112 fridge which works on gas but not on mains, the element heats up but fridge does not cool
Hope this answers all your questions
Leave a comment if you need more help.
Thanks for using Fixya.
Oct 16, 2012 | Thetford Refrigerators
HitI have a Norcold N641 that is having ignition problems. It lights but the igniter keeps clicking and times out shutting off the gas. Occasionally it will stay on but usually it does not.
Check the flame, if there is a clinker (soot) in any part of the flame the signal will not be picked up, or sensed, if there is flick it off, and you should be good to go.
Jun 30, 2011 | Thetford RV Refrigerator - N641 Model -...
1996 Komfort trailer, model 9182 Norcold fridge. Works great on 110V, recently it suddenly quit on the gas mode. It tries to light and flame flame comes on, but once the ignition sequence and sparking is...
The electrode that ignites the burner,also senses flame to keep burner going. Sounds like it's defective. I'd replace it, but take old one with you to match it up.
May 15, 2011 | Thetford RV Refrigerator - N841 Model -...
I have a freezer that does not work it clicks on for a few sec then cuts off what could be wrong
The clicking is the electronic ignitor trying to light the gas.
Either it's not getting any gas to light , or the flame sensor is not telling the computer that there is flame , so it shuts down the gas.
Most fridges have a small shut off right at the gas valve in the back of the fridge , it might be turned off. Put your ear up to the back cover of the fridge , if you hear it sparking and then you hear flame but it goes out after a few seconds , than it is the flame sensor. If you never hear the flame blowing , than it is not getting gas. Could be several different reasons. If you have disconected your tanks , maybe the gas has just not made it to the fridge yet. Newer ignitors try 3 times and then shut down if no flame is detected. Old ones only try once.
Apr 27, 2010 | Thetford Norcold RV Cooler/Freezer
Carbon monoxide into motorhome when using fridge
Check vent panels, on outside, as well as any roof vent for fridge to make sure no obstructions, that would stop the flow of fumes from flame, as well as check the flame on burner is nice and blue, and not orange, indicating rich mixture, which causes excessive fumes.
Apr 26, 2010 | Thetford Porta Potti
Thetford caravan fridge freezes all food in fridge does anyone else have this problem / what can be done? Not sure of actual model but on manual says N80 - N150
Thats a Norcold compact fridge. The most likley problem would be the thermister. Need to do an ohms reading. From inside of the fridge remone the thermister from the fins and unplug the wires. With a VOM set it on Ohms, touch the wires with the probes/ does not matter which probe to wire/ hold the bulb end of the thermister between your fingers, your reading should stat at about 7000 Ohms. Stick the bulb end of the thermister in a glass of ice water, reading should start climbing and go to about 22000 Ohms. If this happens the thermister is good and you need to look elsewhere. If it does not test out you need to replace the thermister. The thermister is a thermostat that controls the heat source that makes the fridge cool. If the thermister reads good you may want to get the circuit board tested.
Hope this helps
Thank you for using Fixya
Jerry
Mar 29, 2009 | Refrigerators
Thetford fridge type C11[fitted to caravan]model N80 PL R
This Caravan is a recreational vehicle? If you have an ammonia absorption refrigerator in the unit, and you smell ammonia, your fridge is leaking. This can be a health hazard. Park the unit and get the fridge serviced, they are repairable by independant service personnel. There are only 2 in Ontario Canada. If you go to an RV shop, the will only want to sell you a new fridge.
Good luck, try a search in your area for ammonia absorption refrigerator repair in your area.
Peter.
Jan 04, 2009 | Thetford Porta Potti
Refrigerators Logo
699 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
