Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Kodak EASYSHARE 5500 will not print with black ink
Changed cartridge, installed new updated software, ran test page printing and calibration steps, cleaned cartridges, etc. No resolution found. The copier and scanner function work fine though black printes as gray. Any suggestions?
allfammed@aol.com
  • 5 more comments
  • salshop Aug 19, 2008
    Same as the previous - This printer sucks!
  • gizel46 Sep 20, 2008
    Same problem, thanks for the help
  • Anonymous Oct 17, 2008
    Same problem here too. Suggestion: Do not buy a Kodak printer.
  • nscholberg Dec 06, 2008
    I have replaced the ink, run maintenance (several times) - still no black.
  • jrafk Dec 08, 2008
    my5300 kodak will not print. changed both cartridges. will not copy either.
  • Anonymous Mar 23, 2014
    ESP 5250 will not center so I can install ink. I selected an option install ink and still not working. How do I update firmware or because I have this option is it already updating. After updating do I have to reinstall wifi
  • Anonymous Mar 24, 2014
    I installed new ink cartridges and now it will not print. What do I need to do?
    Scholar:
  • 96 Answers
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Posted on Aug 19, 2008
  • Dorothy Shaffer
    Dorothy Shaffer Apr 05, 2014
    Yes but it didn't work. Print still looks crappy still no blue or red.
My kodak 5500 AIO easy share printer will not print black ink.
follow the step by step solution from kodak.
Choose All-in-one printer and then Print quality and follow the further steps. I think it's a problem with your printhead.
Oct 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Black ink is not printing
The head is either blocked more than you can clean off, ehich happens and the only solution is a new head or printer, or the print cartridge you fitted is not recognised and is not being switched on by the printer to use. Use a Kodak print cartridge if you have used a compatible version and see if this works.
Sep 16, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
I have a Kodak Easy Share 5500 AiO Printer. I was
Bad new catridge not impossible, I would return the catridge to the store.
Sep 03, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Just changed ink everything is purpleish pink esp3 kodak printe
Pink color usually indicates, color cartridge bad,
Try cleaning nozzles, head cleaner, alignment, calibration
Print off a test page,
If still bad, New cartridge, it's a bad one.
Hope this helps
Richard.
Apr 18, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
My Kodak will not print any color beside blue
Call Kodak and ask for a solution. Most likely they will give you a new print head and cartridge.
Apr 15, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Light grey or no black printing at all!
barb i suggest u call kodak support for a new printhead
their number is 1-800-235-6325
Aug 05, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printing problem
Since it sounds like you've gone through all the steps to clean the print head, I would suggest trying a new black cartridge. There may be a problem with the one you have.
May 27, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Not printing black
Everytime you install a new cartridge, you should print a test page which will allow the printer to auto adjust to the target print.
May 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Color printer cartridge problem 5300 printer
Had a problem like this and contacted Kodak and they sent me a new print head. Solved the problem.
May 05, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Black INk Problem
Try calibrating and cleaning the printhead in the kodak aio home center software.
Dec 19, 2007 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
645 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
