Here's a great video repair tutorial that we've put together to try and help you with the repair on your Hoover WindTunnel. I hope that this helps you with your repair. If you found this solution helpful, please rate this repair video by clicking on the 4 Thumbs Up Icons in the top right hand corner of my repair solution. Feel free to email me at [email protected] if you have any questions about the repair!
i dont have the vacuum and manual doesnt say anything but most vacuums shut the brush off when the handle is in the up position make sure of that and if something is broken there is a two yr warranty for thoes i saw.. good luck.
The other possibility is there is a blockage in the foot. these models have dual channel air flow (windtunnel) and become blocked when not cleaned depending on use. under the roller there is a cavity that can be removed for cleaning. a hot motor can be caused by poor air flow.
these dark marks are burn marks from the beater bar itself. most walmart, kmart, and target shelf vacuums from hoover, dyson, and any cheeper vacuum has a hard bristle system. I've noticed even on the high end hoovers as well that they do the same thing. the best way to save your carpets is to see if there is a replacement beater bar that can be substituted for your vacuum. i dont know what style of beater bar that particular one is but check with your local vacuum repair center to see if they have something with softer brushes you can use insted otherwise i would recommend a new vacuum with softer bristles. usually something that is half as stiff as what is already on yur unit. you culd also try lifting the hight setting as a temporary solution.
