Question about Toshiba Satellite A215-S7422 Notebook
What kind of wireless router is acceptable for this computer
It has built in wirelsss
  • sevsun Aug 18, 2008
    Thanks for the response
    I have a cable connection, what shall I look for
    President:
  • 2,961 Answers
Any make of router will be compatible, but depending on whether you have a cable connection or a dsl connection, there are 2 types, as each router is different
Posted on Aug 17, 2008
My router won't accept password that is on printout from when setup
Check the wireless settings of your router. Connect the computer to the router and open the setup page of the router. The wireless settings might be changed. Follow this link to find wireless network key
Nov 28, 2011 | Linksys Wireless-G WRT54G Router
I am trying to connect a wirelsss printer to my 3G Router - DIR-412 and it is asking for a WPA security passphrase and I can't find the passprhase. I have tried to go on the 192.168.0.1 site, but...
I have an easier way to find your passphrase, but ONLY if you have a computer connected to the router wirelessly. Logging into the router and trying to find out the passphrase can sometimes not work either because a lot of the time, it is blanked out for security reasons, of course.
This program finds saved passwords on your computer for wireless access points. You can read more about it here, if you'd like, but the first link gets you right into the action.
Jun 12, 2011 | D-Link DIR-412 Mobile Broadband Wireless...
How do I connect my HP 8250 Wirelessly? I have a router and a Linksys wireless-B adapter.
Make sure your router is set to accept Wireless-B connections...most aren't. Log into your router and setup wireless, using an SSID and security. Then connect with your laptop and you're good to go.
Mar 12, 2011 | HP - HP Photosmart 8250 printer
Set Linksys router password
You need to login into your router GUI for that.
Apr 02, 2010 | Linksys Wireless-G Broadband Router
Cant sign in to wireless password not accepted
Try to connect your computer with an ethernet cable with the router
Open the router interface using the default gateway that your computer is receiving
Under Wireless, select security and check the security mode and check the compatibility with your operating system.
Remove all preferred wireless networks from computer
If the compatibility is appropriate, and if security key is exact(case sensitive), this is sure to work
Jan 17, 2010 | Linksys WRT54G2 Wireless Router
What do I need to conect my wireless encore router
you need to have a LAN card, but normally, all computers have built-in lan card provided its a new computer. make sure you also have a broadband connection
Apr 02, 2009 | Encore 802.11G WIRELESS LAN ROUTER...
Wireless connectivity with Vista
since you have verizon modem wireles router..
i have the same issue with the same model...I call verizon and tell the issue...verizon accepted that modem router have problem in wireless...i know that all my computers have no issues because i maintain and built those computer by me..
then Verizon send a new and different modem router...this time it works fine...since i received it last week. call Verizon regarding the wireless issues ..tell them too that you have some dead spot on your wireless..like if you move away more than 15 feet..your wireless connection get lost..
i hope this might help
Mar 16, 2009 | HP Computers & Internet
Wireless problems
You need ethernet for this. No router I have seen in all my years of networking will accept a USB plug
Sep 03, 2008 | Siemens SpeedStream 4200 (13A4200001)...
I need to connect a real router with more ports to it 4-2 pcs
Connect the LAN port on the Barricade to the WAN port on your wireless router. The Barricade should be "plug-and-play",
i.e., no need to configure it. Similarly, the WAN port on the wireless-router is plug-and-play, so it should automatically get an IP-address from the Barricade.
Use an Ethernet cable to connect the network-port on your computer to one of the LAN ports on the router.
Then, start Internet Explorer, and connect to the web-server "inside" the router. Run the "Wired Network Setup Wizard", and then the "Wireless Network Setup Wizard". When you're done, then your "wireless" device(s) (iPod Touch, laptop, XBox360) should be able to make a wireless connection.
Note: no need for any CDs to "install" anything.
Sep 23, 2007 | SMC Barricade SMC7401BRA (SMC7401BRA-ADSL)...
Toshiba Satellite A215-S7422 Notebook Logo
20 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
