Question about Linksys Ultra RangePlus Wireless Routr Router
How do I make it secure on my mac I could not read the CD
My wireless is now working through the house, I want it to be secure and do not know how to do it on the mac as I could not use the CD for setup
  • 298 Answers
You can manually setup the security. You can check this link on how to manually setup a security. You follow these steps.
1. use a computer that is wired direclty to the router. Open you browser and type this number in the address bar. http://192.168.1.1. no username and password is admin. say ok.
2. Once you are in the linksys setup screen, click on the tab at the top that says Wireless, make sure to set the wireless setting to manual setup and hit save settings at the very bottom of the page and once your back look at the top where you clicked wireless, right under that click on the subtab that says wireless security. Set the security mode to WPA-Personal. and on the WPA-Shared key box type the password that you want to use. (it should be a minimum of 8 characters)
Posted on Aug 17, 2008
SOURCE:
How to secure the router
  • First of all you need to change the default password and put your own password.
  • Many routers today will offer two different security schemes: WEP and WPA. We recommend WPA security, since it is more secure than WEP.
  • The SSID is the name that identifies your wireless router. By default, many routers will use the name of the router as the default SSID, for example, Linksys routers will often use 'Linksys' as the SSID. This is a security risk since it identifies the brand of the router and would let any attacker immediately know what exploits to use.
  • If firewall is available then enable it.
  • Disable SSID broadcast
  • Enable the wireless MAC filter.The Wireless MAC filter feature will only allow a wireless device to connect to your router if the MAC Address has been entered into the filter list.
If you need any kind of technical assistance you can contact support cell from here
Feb 22, 2013 | Trendnet TEW 652BRP Wireless N Home Router...
Cannot connect wii to router linksys wrt54g v8 i have switched my channels to 1 and 11. I have also updated my firmware to the newest version. I have also tried the manual setup but to no avail I have...
If you have Wireless MAC Filter Enabled on the Router then Either ADD the Wireless MAC Address of the Wii on the router or disable the Wireless MAC Filter on the router, also check the level of the Wireless Security supported by the Wii and accordingly set it up on the Router.
Mar 27, 2010 | Linksys Wireless-G WRT54G Router
Don't know my password , trying to connect with my new MAC
If you are looking for your wireless security code, you can verify it by accessing the router's interface.
Open a browser and go to 192.168.1.1 by default the password is admin. Go to Wireless and then Wireless Security just copy your wireless security settings and enter in on your MAC's wireless settings.
Jun 30, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
My wireless internet wont connect to my computer
If you click on Start, connect to and then select show all connections does your network show up? If not then I suspect your Windows Zero configuration service is not started. Goto control panel, admin, services and be sure it's started.
Are you using any type of security on the router like WPA or WEP? Look at the network settings of one that is working and be sure you are set the same on the one that does not work.
Also, if your router is using MAC filtering be sure your PC's MAC address is added to the routers list of acceptable MACs.
Try these and let me know what you find.
Mar 15, 2009 | Mozilla Firefox
Can't set up security for Netgear 824
LOL you bought it, you get to figure out how it works.
I used a MAC for a day, and the owner had to tell me how everything works. If you can get to the internet, I imagine you can go to www.routerlogin.com and get access to the Netgear. The Wireless Settings tab on my Netgear brings up text sensitive help on making security and wireless work.
Carl
Mar 09, 2009 | NetGear RangeMax WPN824 Router
DLink Adapter Will not detect our Wireless Network!
are you broadcasting your SSID from your router? or maybe you filter your mac address....
Either way try going on this website, http://www.cas411.com/ShowArticle.aspx?ID=68 anybody with a wifi connection needs to read this to try and secure their connection.
Alex
Feb 15, 2009 | D-Link AirPlus G DWL-G122 802.11g/b...
I just bought a used powerbook g4 laptop. It worked great and I used it at work to connect wirelessly to the internet. I brought it home and cannot get it to connect to my wireless network. I have a belkin...
You could try changing the security. Some of the older laptops have trouble with the new WPA2 security. Use WEP and you should be OK if this is the problem. Good luck TT
Dec 13, 2008 | Apple PowerBook G4 Mac Notebook
I need the driver for the d-link wua2340 for a mac g4
The driver page is here, but no Mac drivers are listed:
Dlink Drivers
Try contacting Dlink, or get another adapter.
Try DBT-120 > Wireless Bluetooth 2.0 USB Adapter
Product Features:
• Sync Data between Your Bluetooth PDA, Mobile Phone, and PC • Secure Encyption for Enhanced Network Protection • Experience The Convenience of Bluetooth Headphones, Cameras, Mice, and Keyboards • Works with PC & Mac2
Aug 13, 2008 | D-Link WUA-2340 (ASKU55774) Wireless...
Change router locaation
do factory reset of configuration settings then log in with the routers default credentials. then change settings to your liking with one exception: DO NOT USE WEP!!!!! At a minimum use WPA 1 personal (with MAC filtering if you know how.) WEP can be hacked in less than 5 minutes.
Dec 13, 2007 | NetGear WGR614 Wireless Router
Purchased a Compaq with a Broad com adapter
It is possible that USR is using mAC filtering as a form of security. Your new Compaq adapter has a MAC address. You can try getting the mac address of this device and input this on the USR
Oct 12, 2007 | U.S. Robotics (USR5450) 802.11g/b Wireless...
Open Questions:
See all Linksys Ultra RangePlus Wireless Routr Router Questions
Linksys Ultra RangePlus Wireless Routr Router Logo
44 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
