Question about U-Line Refrigerator Ice Maker
Have an LG LFX25960TT, It won't make ice
I believe it is due to the automatic shut off being in the off position, the up position, but it won't stay down when I move it down and it says not to force or it can break.
Any suggestions on what I may be doing wrong. I can't find anything in the user manual.
Thx ;)
  • 1 more comment
  • reesersa Feb 21, 2009
    Our ice maker isn't making ice. It doesn't seem to be filling with water yet the water dispenser is working. I've turned it off for several days thinking abby it was frozen within the tubing but it doesn't seem to help. What now?
  • Anonymous Mar 10, 2009
    same as above
  • dukey11 May 11, 2010
    can you post the icemaker part of the manual.
    any pictures of the workings??????
Probably need a new spring but I don't know how to place it.
up load drawings or pictures to dukey@mail.usa.com
Posted on Dec 18, 2008
The machine will make a couple of cycles of ice then stop. If i turn it off to clean then turn it on it will work for a few more times but then stop again. Any ideas?
Sounds like the bin switch. If it stays in the open position then the machine thinks it is full of ice and go to automatic shut down.
Sep 19, 2015 | Manitowoc Ice Machine QD-0212A Air Cooled...
Ice cube dispenser
make sure the ice maker lever is in the down position, when removing the tray the arm was probably moved to the top(off) position as if the tray was actually full which would shut off the ice making process
Aug 30, 2012 | LG LFX25971ST Bottom Freezer French Door...
Ice cube tray won't stop making ice.
This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply.
Thank you
Rick
Mar 12, 2012 | Refrigerators
My circuit breaker won't stay in the on position. when you try to flip it to the on position it automatically goes back to the off position
either the circuit breaker is faulty or there is a fault in the circuit, this is something that would need to be checked by a professional
Mar 12, 2012 | Electrical Supplies
LG Refrigerator LFX24971ST - ice naker does not make ice
Arm should not be in up position unless harvest cycle is in progress. Or unless you manually put it there to cut off Ice Maker. Most likely ice maker is defective
Nov 12, 2017 | LG LFX25971ST Bottom Freezer French Door...
My LG LFC25760ST freezer light no longer works. For some reason I can not pinpoint we had a large accumulation of frost/ice on the interior surfaces. Maybe due to a big load of moist grocery packages. ...
better check the connection the leads to the fuse..see if it shorted, and also check the bulb, if you have a contnuity tester it will helps a lot
hope this will solve your problem
Oct 31, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Sep 14, 2008 | LG LFX25960ST Stainless Steel French Door...
Have an LG LFX25960TT refrigerator with in door ice maker. The ice maker only makes 2 to 3 ice cubes at a time. (Too slow for my family's needs.) It appears like it doesn't get enough time to fill. Is...
Check to make sure the water supply to the refrig is good and the inlet screen where the water line connects to the refrig is clean. You can change the amount of water fill by pressing the button on the left side of the ice maker. (indicator lights above button show setting) Selecting "Ice Plus" on front of dispenser panel increases ice production for a 24 hour period. Ice maker should produce 6 cubes per cycle, aprox.. 100 to 130 cubes in 24 hours depending on freezer compartment temp, room temp, number of door openings, etc.
Sep 10, 2008 | LG Refrigerators
Have a LFX25960TT L G fridge . missing ice bucket and Auger needed to deliever ice cubes to door dispenser. Can not find a parts list of what needed service supplyer thinks that ice bucket assembly may be...
Hi, I have a lfx25960tt with a deep scratch door. Can I repair the door with some sort of metal scratch remover? Also do they sell just the door metal cover?
Mar 29, 2008 | Refrigerators
U-Line Refrigerator Ice Maker Logo
229 people viewed this question
Top U-Line Refrigerators Experts
billconfused
Ilia Bichin
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
