Question about Toshiba Satellite R10-S802TD Tablet PC
DSL Connection For the past 3 days I have been having an issue with connecting the toshiba with my verizon DSL Help!!!
    Scholar:
  • 152 Answers
Are you trying to connect wirelessly or connecting directly to the modem? Have you added any new software or hardware within those past 3 days? There may be a conflict if you installed something new. For hardware - check Device Manager for any yellow icons for conflicts. if you installed software, delete it and see if that solves your problem. Remember to back up anything that is important from new software that you recently installed.
Posted on Aug 22, 2008
SOURCE:
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
My new Nexus 7 wont go past the "Select Wi-Fi" screen although I have set the Wi-Fi up
I assume you're using a secure Wifi connection with a password and it seems like that authentication is not working. You could try using an open wifi access point to eliminate the possibility of this authentication issue.
Oct 04, 2014 | Google Nexus 7
Google play not downlaoding apps
Try going Settings>Accounts>Google> Tap your account> Three dots in the upper right (or press menu button) "Remove Account" ... then read your account .. then if you want, clear Play store cache and data and try it
Dec 26, 2013 | Irulu 7" 4gb Mid Google Android 2.3...
Craig tablet cmp741e
This can be caused by a number of issues most have to do with the router itself and not the tablet. First, let's make sure the router DHCP Server is not frozen so take the following steps:
Step 1: If the router is separate from the Cable or DSL Modem, power down the router/wireless, next power down the cable/dsl modem. Power up the cable/dsl modem wait 60 seconds then power up the router/wireless wait 2 minutes
Step 2: Try to connect to the wireless
Step 3: If you have a modem or wireless router supplied by Comcast, Verizon, AT&T or any major carrier, contact them asking them to walk you through resetting and rebooting and updating the firmware to the router/wireless.
Step 4: After the reset and update try to connect, if it fails move on
Step 5: Log into the wireless/modem - let's change the wireless encryption. Go to the wireless settings, change the wireless settings to WPA Personal and add any pass-phrase. Try to connect using the new pass-phrase.
Step 6: If you still can not connect, as a last resort switch the wirlesss encryption to WPA for testing. Try to connect, if this works contct the vendor and have the modem replaced.
Jun 08, 2013 | Curtis Klu 7-inch Touch Screen Mobile...
Candy Crush Saga won't connect to Facebook to sync
I never could connect on my android 2.3 phone, but then I read something online about needing to uninstall and re-install the facebook app on the phone... the facebook app came with my phone, and my phone would not let me uninstall it! I WENT TO THE GOOGLE PLAY STORE AND SEARCHED FACEBOOK. When it came up, it had the option to update my facebook app, so I updated it, after that CANDY CRUSH CONNECTED TO FACEBOOK NO PROBLEM... go figure... my phone has automatically updated the facebook app several times, but the candy crush app would never connect until I updated the app manually using the google play store... Bizare!
Feb 18, 2013 | Apple iPad Tablets & eReaders
Display has lines and flickers. Better if the display is opened or tilted on its hinge ( has funky tablet hinge)
Press firmly down with your thumb on the laptop base just above the F4 / F5 keys, if the display improves while doing this it is simply a loose connection which is common for tablet pc's. If this does not help, then it is either a short in the connection or worse case an issue with what is called the inverter. In any case this is an issue that requires opening up your laptop to fix. If you are not comfortable doing this sort of work call up your local computer repair shop, I recommend a personal business over a corporate one, as you will receive better customer service and more likely than not if it is a simple cable connection issue small businesses will take a few minutes out of their day to fix it on the spot and charge you far less.
May 16, 2012 | Fujitsu LifeBook T2020 Tablet PC
I want to start inter net from my laptop what to do
Hello Punitrava, Hi, you can connect to the internet several ways, here are the common ones. 1. Via a free WIFI hotspot, find a WIFI area like in malls or coffee shops and enable you WIFI connection on your laptop. after enable the laptop detects the wireless connection and simply connect. 2. Via a USB modem, inquire about this on your wireless telephone company. 3. Via the Local Area Network like computer shops, insert any available LAN cable on your LAN connection, you need to consult the LAN administrator. 5. Via a DSL connection, just plug in the LAN cable from a DSL to your laptop. you need a DSL/internet account from your telephone company.
Jan 08, 2011 | Compaq Tablets & eReaders
I cannot connect to the internet. My wireless connection says that it is connected to my wireless hub. All other computers in the house hold are connecting to the internet wireless, so it is not a wireless...
Do you have anti-virus installed? You may have a virus that prevents you from surfing the net.
Also check if you are getting an IP address. Go to start>run>type in cmd and press enter. On the command prompt(black screen) enter in ipconfig and see if you have a IP address
Jun 03, 2010 | Toshiba Portege M200 Tablet PC
Unable to get Wireless to turn on
Sandy,
What was the earlier problem?
Do you think it is/was/might be related?
How did you get past the issue? If you formated, you have to go through "Software Setup" find it at Start, All Programs, Software Setup. (tc1000) or if you restored with the factory discs (tc1100) then it should be done. If a tech "restored" your tablet with other than the factory restore discs, then Q menu may be impaired or nonfunctional.
Is the card actually there?
Are the cables connected?
Is the card the original hp card? Some others will not work with the Q Menu.
Go to hp.com, navigate to the tc1100 support page and download all drivers or recent updated drivers.
Install the updates and you should be fixed.
HP will sell you restore discs for $10.72 (thats what I paid last fall) that will install the correct drivers for the unit. Cheap at twice the price. You will need a keyboard (USB generic will work if you don't have the original detachable) and an optical drive (USB CD Drive) basically to do this.
My friendly local tech is at $50 for basic service, and if you can back up to another PC (cat 5 cable connection is fastest) or a card, then a reformat never hurts a thing, kills many troubles too!
Best Luck, Blaino
Apr 23, 2008 | Compaq tc1100 Tablet PC
Verizon broadband wont connetc though it finds the network on q1 with XP.
If your bills are clear and the service from the ISP is ok then check the drivers for the usb modem , remove the drivers and the software running the modem , remove the modem too . first install the software and drivers then connect the usb when required . The com settings can be configured from the control panel
Nov 18, 2007 | Samsung Q1 Tablet PC
Toshiba Satellite R10-S802TD Tablet PC Logo
418 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Ekse
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
