Question about Maytag Neptune MDG5500AW Gas Dryer
No heat maytag mde7500ayw
Bot dryer at a sale. had to change cord. wired wrong and blew braker. fixed and now everything works except heater. checked all fuses with ome metter and all look good.heat relay seems to work. what should i do next?
Merrill from dewey az.
  • Maytag Master
  • 5,568 Answers
I think the ignitor might have failed, that could be why it was being sold.
This isn't generally a tough replacement and not too costly.
If you are fortunate enough to be in the US and near a Johnstone Supply, you can save 20-50% of the normal dealer price that is somewhere between $30-40 US.
They call themselves 'wholesale' but I have never been turned away in any of their stores
The two links below give you the locations in AZ and the catalog page of available part numbers.
http://www.johnstonesupply.com/corp/AboutJohnstone/StoreLocations/LocationResults/tabid/564/Default.aspx?find=AZ
http://www.johnstonesupply.com/corp/SearchResults/tabid/1781/Default.aspx?search=ignitor&qty=
Posted on Aug 17, 2008
Why won't my dryer heat?
check the following:
Heater element and connections...With an ohm meter check for an open coil
Temperature select switch
Wiring
Jun 25, 2014 | Maytag MDE2400A Electric Dryer
MDE5500AYW Maytag Neptune not Heating
Sure I will help you when that happens that means that your heater core is no longer operating and when the heater core doesn't work when your dryer doesn't heat up anymore so that's your problem I hope I have helped you please leave a response or Stars if I have helped
Feb 07, 2018 | Maytag Neptune MDE5500AY Electric Dryer
Everything works except the heater
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 22, 2010 | Dryers
I need info for changing the power cord from a 3-wire cord to a 4-wire cord. I have a Maytag Dryer Model MDE9316AYW and I am not sure wher to connect the wires. It looks like they connect (from left to...
The correct way is actually as such...Green (ground) to the frame/chassis. Red, white, then black. See the image I attached for a reference.
Hope that help`s. Good luck.
macmarkus :)
Mar 06, 2010 | Dryers
Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
Aug 03, 2009 | Maytag Dryers
Dryer works but no heat. We just moved...
most likely there is something wrong with the way the cord is wired to the machine or the outlet is dead. Dryers dont usually get damaged just by moving them. did u change the power cord. red on one end white in the middle black on the other end and green to cabinet ground.
Jun 12, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer spins but no heat
Did you check the power coard where it connects to the dryer? Start at the source. Make sure that you have at least 110v on each line. The dryer will tumble on 110v but requires 220v to heat. If you have 220v then check the t-stat and thermal cut-out on the blower. Check all wires for loose or burnt terminals. If all that is good it may be a bad motor or timer/control. I'm happy that you have a meter.
Good luck.
Dec 17, 2007 | Maytag Neptune MDE7500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
