Question about Philips WACS700 Shelf System
CD not loading
I have an erratic CD loading,sometimes ok sometimes not. Problem is that CD's sometimes get stuck in the centre, after numerous re boots it sometimes cures itself.Is this a laser problem, can these units be repaired for sensible money? Any help is much appreciated, thanks.
    Problem Solver:
  • 11 Answers
Try a cleaner first as sounds like could be dust on lens, if you have, then is likely to be expensive.
Posted on Oct 02, 2008
How do I load a cd? when I open door cd just sits on top...is that ok?
Open the CD draw all the way and a CD/DVD should be pressed gently over the centre spindle until it clicks lightly. Then close the CD draw until it clicks shut. That's it..
Sep 06, 2013 | Acer Aspire V5-571P 15.6-Inch Laptop -...
Thanks for giving me the reply.I am not in a position to play any disc because the disc tray is stuck up in the system and does not open.I had got the lens pick up unit changed a few months back from Sony...
Hello
The fault now is with its CD mechanism. It may be either by borken loading belt, of the trouble with the gear wheel set that loads and unlods the disc tray. OK.
Jan 18, 2012 | Audio Players & Recorders
BOSE 3 CD PLAYER DISC 3 SHOWS DISC ERROR AND WILL NOT EJECT. TRIED SLIDING OLD DISC UNDER STUCK DISC AS RECOMMENDED WITH NO SUCCESS
hi,
Its because of the disc three is out of its potion in the tray. You have to remove the mechanism to remove the disc from the tray. You have to be very carefull while removing the mechanism because the cd loading mechanism is a very complicated part of cd players . Because when you remove the mechanism to eject the disc, the timing of of the the machanisum can be changed this will lead to malfunction of the loading arms and wheels and will cause serious damages to the mechanism. If you are not aware of how to remove the the try to contact the bose servicing centre.
If you are confident the try to remove the cd manually.
OK
Nov 25, 2011 | Audio Players & Recorders
My Sony CFD SO1 keeps skipping/display light keeps flashing
That is an electronic problem. Probably a just-about-to-break cable in the motor of the CD drive, that sometimes causes a short and turns off the unit, or sometimes makes it to comport erratically and produce the buzzy sound. If you have electronics knowledge, then you may open and check the wiring harnesses. If don't, take it to your local electronics repair.
Nov 20, 2009 | Sony Boom Box With CD Player & Cassette...
Erratic gear change
it sounds like a partialy restricted transmission pan filer would solve your problem! it is a maintanance and should be done anyway it is much cheaper than your alternatives...good luck
May 22, 2009 | 1994 Dodge Dakota Club Cab
The data on the screen is all loads 90 dgre rotat to norm
Just check that you do not have "hot keys" active on your laptops drivers, Try pressig Ctrl, Alt + directional up
sometimes graphics cards hve a rotate funtion incase you want to work hanging off the ceiling or something :S
Mar 02, 2009 | Dell Inspiron 6000 Notebook
Kenwood RXD25 CD player intermitent??
Hi jenoss
Sounds like the unit has either a failing load belt to the cd drawer mechanism,not allowing the transport to fully load the cd. Give the unit a gentle tap just after the drawer closes and see if it resolves the problem.
OR a faulty spindle motor, you will have to take the lid off and after pressing play, give the disc a gentle "kickstart". If it then begins to run, then the motor is the problem.
If you find it is neither of these, get back to me here and I we shall go further
regards
Graeme
Mar 16, 2008 | Audio Players & Recorders
Philips WACS700 Shelf System Logo
108 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
