Question about Mitsubishi WS-65809 65" Rear Projection Television
Mitsubishi WS-65809 65 in. (Won't stay on)
I go to turn it on and the red light indicator comes on for 1 second and then it clicks off. The TV screen does nothing. I checked the clear bulb (fuse) by were the power supply comes in and it's OK.
this is about 6 years old now and has been a great TV till this.
  • 927 Answers
Good Day, 4mlspro;
You can try this or call an Authorized Service Center and get an estimate on the repair, $450.00 to $650.00;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB (NOT SHOWN IN THE SCHEMATIC). 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Posted on Aug 31, 2008
Mitsubishi WS-65511. Won't stay on.
Bad filters in the main microprocessor. good luck.
Aug 30, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Stays on for 2 seconds and switches off
A 2-2 code on that unit means over current shutdown. 95% of the time that code indicates defective convergence output IC's.
Jun 09, 2009 | Mitsubishi WS-65869 65" Rear Projection...
My tv ws-55819 tv won't turn on it cliks on but it won' syat on
ok when the power is plugged in hold down the menu + device buttens for five sec what is the error code there should be two sets of numbers....
like 1 pause 2 let me know and i'll see what i can do!
Feb 01, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Tv will not power up, shuts off after 10 second
http://serviceman.site88.net/index_files/MitsubishiTV.htm
Oct 01, 2008 | Mitsubishi WS-65857 65" Rear Projection...
Mitsubishi HDTV 1080 WS-55859. Error Code 12
Did you push in the device and the menu buttons at the same time and get the error code...  I have the same problem and I get a 1,2 code....   I am looking for what the codes stand for...
Have you got any help on this....
Scott
mu email is smartin38@verizon.net
Sep 11, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Lightning strike
press menu and input both in together on the front of the TV and hold them both in together for 8 seconds then let me know if the LED blinks a two digit code.
Jun 10, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
213 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
