Question about GE XL1800 1100 Watts Microwave Oven
Light not working
GE model# jvm1860bd001 surface light and interior light not working but everything else work fine. Need help
  • Anonymous Nov 18, 2008
    i have the same problem got some bulbs from lowes and they dont work?
    Champion:
  • 225 Answers
Put new bulb or wiring
Posted on Sep 06, 2008
Changed the light bulbs in my ge jvm315 and know the surface light will not turn off ?
This sounds like the control board also called a smart board in some models has to be replaced.
May 02, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Oven Won't Start
You need to use an ohm meter on the switches to verify that they are actually opening or closing electrically. You could also have a bad thermal protector. Check for one on/near the magnetron to make sure it has continuity. And, there are many other less likely causes, as well. Too many to list.
Apr 16, 2014 | GE Microwave Ovens
How do I remove my ge above the range microwave model jvm1860bd001
You can download GE owner's manuals and installation instructions here.
Need your controller repaired?
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 17, 2011 | Microwave Ovens
Microwave will not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
l'l'l'l'l'l'l'l'l'l'l'l'
Aug 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Everything appears to work but turntable and light on interior.
It's probably your bottom door switch. See this helpful file.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
May 04, 2010 | GE JVM1740DM Microwave Oven
Surface light "nightlight" will not work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Sometimes this will also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Feb 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Xl 1800, model JVM1860BD001
The parts need to be replaced by an authorized repair service!
FIXD???????????????NOT FIXED
Sep 02, 2008 | GE JVM1860 Microwave Oven
Can you tell me what the wattage is on model #JVM1860BD001
On page 11 of the manual in very small print it says "1100 Watts".
Aug 19, 2008 | GE Microwave Ovens
GE microwave interior light bulb replacement.
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 03, 2008 | GE JES1289SK Microwave Oven
My GE JVM1790SK
If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 You may have a bad door switch. We also have a file on door switches at our site.
Feb 15, 2007 | GE JVM1790SK Convection/Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
129 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
