Question about Garmin nuvi 350 GPS Receiver
My garmin gps doesnt have the turn by turn voice sound anymore.
My uncle accidentally pressed something that disabled the voice prompt BUT when i plug in an aux cord it works well.. is there anyway to re-boot the system so i could have the sound back again? or what do i do?
EAT A **** AND UNLOCK
Posted on Aug 18, 2008
Speaker turns on but no sound. If i plug into aux cord it workes
check the speaker wire is your music player is connect properly. if not work something wrong your sound ic or speakers, aux port means that any other items plug in socket,ex mobile phone or dvd players , mini disk player
Feb 07, 2018 | Audio Players & Recorders
Tip
Samsung Intensity: How to avoid the voice recognition prompt
The Samsung Intensity has many nice features. It comes equipped with voice recognition software, which many people like. However, for others it is merely annoying. If you keep your phone in your pocket or purse, you might hear a muffled voice saying "Please say a command" from time to time as the phone's voice recognition button is bumped.
Fortunately, you can disable this voice prompt (if you want to) with just a few simple steps:
1. Press the voice recognition button on the upper right hand side of the phone.
2. Press the right options button to go to the Settings.
3. Select Prompts (#5).
4. Select Mode (#1).
5. Select Tones Only (the last choice).
6. Hit OK to save the change.
Now, when you accidentally bump that button, you'll just hear a short single tone, rather than the voice prompt.
If you want to reduce the volume for the voice recognition (either for the voice prompt or for the tone) that can be done easily as well. Follow the steps above to get to the Prompts menu, and select Audio playback (choice #2). Highlight the choice for Earpiece, and hit OK to save your choice.
The voice recognition function will now use the earpiece to play any sounds, rather than the speakerphone, so whether you set it for a voice prompt or a tone, the sound will be much quieter and hopefully you won't even notice it.
You can also lock the phone when you're not using it, which will disable the voice recognition button so you don't have to worry about bumping it. To lock your phone, just hold down the zero (0) key for two seconds. You'll see a message on the screen that the phone is now locked.
on Jul 09, 2010 | Samsung SCH-U450 Cell Phone
Change language to English
You can change settings on your speakerphone. To do
this, turn off your speakerphone, then press and hold the call button and move the power switch to the "e" position
until you hear "welcome to setup".
Follow the voice prompts to change settings for:
Language
Enable/disable voice prompts
Enable/disable Name/Number Caller ID feature
Size of favorite contact list (10 or 25)
Mar 10, 2014 | Motorola Mobility T325 Bluetooth Speaker...
Not having success saving new message for night or day prompt. WHat am I doing wrong?
Hi, the prompts on the Samsung DCS Voice Mail ask you to press 2 when you have recorded your message, this actually deletes the message, you have to press the # key to save. I have posted you a video with training tips on the DCS voice mail, others like this 1 are on Youtube by 'abbeytel'. a text version is on
http://www.abbeytelecom.com
Dec 23, 2010 | Samsung DCS 12 Corded Phone
Is there a way to disable the voice recognition button on my Samsung intensity??? Whenever I go to slide it, I hit the button, and my phone talks, even when i hav the volume on vibrate only.
I have the same problem with my Intensity every time I keep it in my pocket. Unfortunately, you can't disable the voice recognition function completely, but you can make it more managable.
You can get rid of the voice that says "Please say a command" when you hit the voice recognition button, and instead make it just a single tone by following these steps:
- Hit the voice recognition button on the side of the phone
- Press the right option button to go to the Settings
- Go to #5, Prompts
- Select Mode
- Select Tones Only (the last option)
- Hit OK
You can also reduce the volume by changing the output from the speakerphone to the ear piece, to make it quieter. Go to the Prompts menu like you did above, and select #2, Audio playback. Set it to "earpiece" and hit OK.
Now, when you accidentally hit that button, the phone will just emit a short tone that you probably won't even hear. Hope that helps!
Jun 07, 2010 | Samsung SCH-U450 Cell Phone
Computer will turn on but wont stay on
Most likely your power supply is faulty. You can test it with a voltmeter to determine if this is the cause or if it's the motherboard.
Sep 15, 2009 | E-Machines eMachines Desktop PC
Deleted voice prompt
CALL technicle suport at ;
800 707 9971 (1) English (4) (1) maestro 4040
I hope they will be able to solve your problem
"Did I answer your Question?
Apr 25, 2009 | Nextar X3-03 Car GPS Receiver
P4vmm2 wont boot up
Disconnect power cord, remove the button cell battery, press the power button to dissipate any stray volts, replace button cell, plug in cord and re-boot, this will reset bios to default settings.
You will get a check sum error so enter bios to re-set date time and other settings.
May 13, 2008 | EliteGroup P4VMM2 Motherboard
Delete old voice mail - program new voice mail
You can usually access the system voice mail setup from any extension.
Press Speaker
Dial ext 200.
When asked for security code, dial *,2,# (dial it twice if there is no code).
When main greeting begins, dial 632.
Using the soft keys under the display, press MORE, then MGR, then CHBX or, follow voice prompts if non-display phone.
Follow voice prompts. Remember, 1=Yes, 2=No.
Mar 10, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Got an aux cord to plug my ipod in, doesnt switch to "aux in" mode
According to the manual, you need to "enable" the AUX 1 or 2 thru the initial settings menu.
Press and hold the SRC until the unit turns off. Then press and hold the MULTI CONTROL (knob) until the Language appears. Turn the knob to cycle thru the options, select AUX 1 or 2 and press the knob again to select ON.
After selecting them to on, power the unit on and press the SRC to cycle thru the sources to find AUX 1 or 2.
The owners manual is here if you need it;
http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070337_338818745,00.html
Best of Luck.
Nov 18, 2007 | Pioneer DEH-P6900UB CD Player
Garmin nuvi 350 GPS Receiver Logo
61 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
