Question about Whirlpool ET8MTKX Top Freezer Refrigerator
Water underneath the Veggie Crisper
I have an ET18NKXAW01, it has water that accumlates at the bottom of the refrigerator (underneath the vegatable crisper) How do I stop this water?
  • Indiasman Jan 27, 2009
    Water pools under the veggie crisper.
Sea Breeze
  • 4655 Answers
SOURCE: Whirlpool Refrigerator(side by side) leaking water
First question would be is your ice machine leaking? If so then disable the ice machine until we can find the cause of leaks and repair them. Is the freezer freezing well? Food compartment temps OK?. Let me know and I will work to help you resolve this. Sea Breeze sea breezehvac@yahoo.com
visit my site below
http://servicepartstec.blogspot.com/
Posted on Mar 30, 2009
SOURCE: When refrigerator defrosts, water drains down into
i have the exact same problem...anyone??? now my fridge won't get cold at all and the freezer is still frozen
Posted on Apr 16, 2009
Maytag317
  • 1136 Answers
SOURCE: water collects in bottom of refrigerator
HI, First thing you do is remove the floor panel of the freezer. Do you see ice?
If there is ice, remove the rear wall of the freezer as well and start removing the ice. There will be down inside the drain hole also. A hair dryer works great for this project.
Please do not use sharp object/tools.
Now that you have the ice out of the drain, There is an after market drain transfer heat strip kit you need to buy and add.
Please let me know if I can help you. I have the kit on my web site www.whirlpoolpartssurplus.com
Thanks
Vic
Posted on May 23, 2009
mgprice
  • 744 Answers
SOURCE: water pools under the veggie crisper
yoor problem is with the drain, when your refrig goes into self defrost the water melted from the defrost needs some where to go. There is a drain for this purpose....it is normally a tube that leads from the rear of freezer to pan by compressor. when this gets blocked the water has nowhere to go except into the freezer vent and down the bottom of the refridge compartment. you will need to clear the blockage in the drain tube...if you are still haveing a problem i can tell you how.
Posted on Jun 22, 2009
marka19
  • 1430 Answers
SOURCE: Refrigerator has water dripping inside the unit down the back
The problem is the drain is clogged. Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½” in diameter this is the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travel down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. You can enter your model # at www.appliancehelponline.com for a diagram or illustration of your refrigerator. Not all models are available.
Posted on Apr 19, 2010
Water leaking bottom of crisper.
You may just have to manually defrost it.
Dec 16, 2014 | Fisher Refrigerators
Cold water collects in the bottom space below the drawers
this is just condensation as the fridge is not frost free.try placing a sheet of tissue in the bottom of the salad drawer and one under it, take out about once a week to keep dry
Mar 08, 2010 | Frigidaire FRT21H8 Top Freezer...
Water accumlates inside refrigerator
The defrost drain is plugged up. You must access the evaporation department and open that drain. I have free repair manuals HERE
Jan 19, 2010 | Refrigerators
Water under crisper drawers and then leaking outside underneath.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Sep 28, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Kitchenaid refrigerator mdl KTRS22M has water under veggie drawer
Hi, water could be excessive moisture, check door gasket, or check drain at back above veggie drawers, could be block, make sure produce not blocking drain hole, clean, check carefully for drain.
Aug 02, 2009 | Refrigerators
Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Jul 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Jun 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water under veggie bin in fridg. model frigidaire F44Q21RJ,
possibility's:
1 There is a drain that carries away the water under the cooling coils. These coils are in the freezer section.
2 The damper going to the crisper( s) is open too far allowing cold air to cause condensate on the fridge wall or bottom.
3 The freezer section is not defrosting and there is a spot where the ice buildup is allowing conductive cooling into the refrigerator section and therefore is allowing condensation on the refrigerator wall or ceiling.
4 The refg section has a heater (possibly not positive) in the area of the door frame, or it may have a "power saver" switch. This switch and the heater (if it has a heater it may not have a switch) are designed to stop condensation on the refridg while running. I fit is placed in the "power save" mode it turns off the heater. But, if you live in extream humidity (Great lakes east side or Gulf coats Houstion...) the humid air will condensate water out and it will collect and settle on the floor.
5 Door gaskets are not sealing especially on the bottom of the door. This allows warmer air into the fridge section and it is condensation on floor under the crisper.
If you check all of these items and still cant find it please post back and tell me what you did find. So I can help you more. Please rate me as much as possible as Im trying to keep my average up and do the things that will actually educate and help people.
THANK you for using fixya and good luck..
Mar 22, 2009 | Refrigerators
Whirlpool ET8MTKX Top Freezer Refrigerator Logo
41 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
