Question about Coleman Powermate Premium Plus 6250W Portable Generator
Coleman powermate 6560 generator won't stay running
We received the generator as a gift in 2006 and have not ran it. due to TS Fay we decided to test run it to see if it works and it has issues staying on. If I add gas to the collaborator it starts but will not stay running.
  • 5 more comments
  • b is here Aug 17, 2008
    OMG i can't even believe I found this post. We also bought ours on 06/11/06. Pd 500 bucks at Wal Mart brand new. Registered online. Have receipt and everything. We start it and it and the motor runs, but goes up, down, up, down, and does not run at a smooth "rpm" or whatever you call it. Messed up for sure. 500 bucks wasted. THE NUMBERS FOR COLEMAN HAVE ALL BEEN DISCONNECTED how incredibly convenient..... We called Wal Mart and they won't do a thing about it either. Lesson learned I guess. Never buy a coleman generator!!!!!!
  • Lukienet Aug 20, 2008
    I cant get mine to start. Hasnt been used since hurricane charlie. I have the "on" switch turned on, the choke up, and its not even turning. Gas is full and so is the oil. Any suggestions?
  • RUYA Aug 28, 2008
    I'm having the same problem after receiving my 6250 back 3 years ago after being rebuilt. I've removed the air filter and sprayed carburator cleaner in the carb. and even added B-12 to the gas to clean the carb and bowel. At this time it stays running for about 3-4 seconds and kills. This is the first time I've tried starting the gen. since receiving it back, it has been stored in my garage all that time with NO gas in unit until yesterday................. Need some help!
  • Anonymous Aug 31, 2008
    i have coleman powermate pm0545010 new, never used,
    will not stay running, gas not getting to carborator
    where is the primer button???
  • plibby Aug 31, 2008
    What is the procedure for spraying the carburetor as I am having the same identical problem with this unit?
  • plibby Sep 01, 2008
    where is the carburetor bowl on my 6250w portable generator so i can try and clean it so that it will stay running?
Coleman powermate 6560 that runs good but wont gennerate power, i tried to exite it by plugging a drill in & holding the trigger in & turnning it backwards but still no power any suggestions?
Posted on Feb 06, 2010
Most of the time when my coleman 6560 won't run after long periods of non-use. Here is the surest way to get it going: Remove carburetor bowl with 12 mm wrench. You will see a fixed fuel jet screwed into the side of a verticlal tube. (it's the tube from which you unscrewed the bowl screw. The jet is stopped up with varnish. you can remove the jetand clean out the small hole in it, or you can un-plug it without removing it with a (small) paper clip. larrymax@cox.net
Posted on Aug 31, 2008
Spray carb cleaner in the carb and clean it. it a common problem with any gas engine that sits too long get an inline fuel filter and that will help I've had a coleman 6250 about 10 years and no problem. Give that a try....
Posted on Aug 18, 2008
Never  leave gasoline inside the tank for a long time  ,,,,, it become  glue wen dry,,,,,,   ever drain  the tank   eveeerrrrrrr
Posted on Jun 02, 2010
I have 2003 astra Sri Turbo ts hatch the engine light is staying on but the car runs fine? Suggestions on what it could be?
Tags location of knock sensor
https://outofthebooks.top/term/location-of-knock-sensor
Need to locate knock sensor on 1999 camry V6. Where is ... Cabin filter · I have 2003 astra Sri Turbo ts hatch the engine light is staying on but the car runs fine?
Common problems with the Astra G [Archive] - Astra Owners Network ...
www.astraownersnetwork.co.uk > ... > Astra Chat > Astra G
Mar 20, 2007 - 100+ posts - ‎100+ authors
Also, rear disc brakes on the SRi models have a tendancy to seize up ... Pre 2003 2.2i.... about 10mins but the engine temperature stays fine when running. it .... theengine manigement light is constantly on, but car running like a dream! ..... I have a 2007 astra sport hatch sxi 1.6 and seem to have a strange ...
Holden Astra known issues? - Holden - Automotive - Whirlpool
forums.whirlpool.net.au > Automotive > Holden
WhirlpoolDec 12, 2012 - The TS Holden Astras, late 90s to early 2000s, stay away. Unreliable ...People give the TS Astra a lot of flak but its a superb car. We have one ...
Jan 20, 2016 | Cars & Trucks
2006 Chevy Trailblazer started to run rough in idle but only after it warms up. My mechanic got P0017 code on his scan tool and told me I needed to replace the Crankshaf and Camshaft sensors. Both sensors...
Bad coolant temp sensor or EGR valve stuck. You can remove and test temp sensor (the one for the ECM--has only one wire) using cold and then hot water and read resistance with ohm meter.
Jan 28, 2015 | 2006 Chevrolet Trailblazer Ext
Electrical power system service required.....ABS warning light, generator warning light, brake failure...car stalled and wont't restart
usually caused by failed generator. Fix the generator and other lights will also extinguish. The car should jump start, but will not stay running without a charged battery. Recommend removing the generator and take to parts store for testing. Would you like instructions for removing generator?
Oct 17, 2010 | 2001 Volvo V70
Generac gardian model:005885-0 running rough
Check the spark plugs, ignition coil etc and try to start it manually.
Jun 15, 2010 | Generac Guardian Quietsource 25,000 Watt...
Coleman mach fan runs fine but A/C hums intermittently like it wants to start but won't. I'm running it with a Honda 2000 generator. Generator ran out of gas, when I restarted the generator the A/C would...
The issue with the generator that gets low and high when it start running out of gas that effect the A/C and result of high voltage getting to the unit and burn the capacitors and it should by saved by the fuse make sure that the gen not run out of gas if you have the A/C on and that the fuse is the correct one for the A/C and again check the air and see you may got a bad capacitor.
....let me know if that work for you and please do not forget to rate my service so I am able to continue providing same...god bless
1 thump not related
2 thump related but no recommendation
3 thumps related worked some issues
4 thumps related worked all issues and satisfied
Oct 01, 2009 | Coleman Mach III Air Conditioner
2006 Chevrolet impala lean code issue
Unplug the sensor harness and re-connect a and c terminals using jumper wires. You should see about 4.5volts or a bit more from the center terminal (meter(+) to terminal, other lead to good ground. Do this with key on, engine off.. With engine running, (same hookup) You should see a different and varying reading that changes with rpm. Before testing check the vacuum hose going to the sensor to make sure it's intact and has vacuum or test will be invalid. Test procedure I outlined is the last one I remember. Possible GM changed procedure, so best to check a manual if readings are different than what I stated. There are other items that can change mixture but I have seen this a few times. Otherwise, you will need to go through system item by item before finding anything.
Aug 28, 2009 | 2006 Chevrolet Impala
Remington Axcess hedge trimmer wont run at all.
Check your fuel lines. It is probably getting air into the system. Also check inside the gas tank to make sure the fuel pick up line is still attached.
If you need more assistance please provide an exact model number and I can better help you.
Kelly
May 10, 2009 | Remington Factory Reconditioned 17-Inch...
Oil for Coleman Powermate 5000 PM0545305.03
Yes, SAE5W30 is just the right oil for this machine,it will take about a quart to fill it up to the bottom of the threads in the oil fill hole.
The engine of this generator is essentially just like a lawn mower with a fixed throttle setting. You should expect all of the same issues as any small engine that's been sitting for a while. Check the fuel tank for water/debris, check the carb for fouling, check the spark plug, etc.
If the generator has been sitting for 3+ years without running you may need to flash it to get any voltage out of it. If you get the engine running and it won't make any electricity ask me directly and I'll talk you thru the procedure.
I looked on www.powermate.com for an owners manual but they only seem to have the parts list, rats.
Regards,
Carl
Dec 13, 2008 | Coleman Powermate Powermate 5000W...
Start Porblems
This may or may not help. Hopefully it will. We recently purchased this 1998 chrysler town & country. Everything was working fine, started fine, etc. we took it to get emissions done.....passed emissions.. .made it home. i turned the car off to run inside for a minute. came back out car started.. ran for 3 seconds than died out. tried again... ran for 3 seconds than died out... after that it no longer would do anything. all the lights worked except in the ignition module. the top dashboard lights worked though. I then noticed that the "alarm set" light stayed lit. after replacing fuses and running an OBD test and found no trouble codes or issues with fuses it dawned on me it may be the alarm. after searching the internet for hours i found a forum that suggested unplugging the battery for about 5 minutes....rehook it and then try starting it again. well i tried doing that the first time using the REMOTE to unlock the doors and nothing happened. i locked the doors and repeated the same battery unhook-rehook process except without using the remote... (i noticed a lot of forums saying that the remotes can be deffective in that they somehow trigger the alarm if the transmitter is not working properly)... so after unhooking and rehooking the battery and using only the key to unlock it started right up! so i've decided to not use the remote at all and have had no other problems. let me know if this helps
Sep 11, 2008 | 1998 Chrysler Town & Country
Enable Custom Messages
It's hard to see what you recorded the custom messages on, since you left that part out.
I'm guessing that whatever you recorded the messages on has a manual. Try reading it. Is your day greeting a custom message or is it one of the 32 announcements? However you play that message, you need to either replace it, or assign a new message or mode to the auto attendant.
Carl
Aug 25, 2008 | Panasonic KX-T7453 Corded Phone
Coleman Powermate Premium Plus 6250W Portable Generator Logo
2,898 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Rivera
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
