Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Have a sears garage door opener. Thought the buld was burned out and replaced it. Now light will not turn off.
Garage door light will not turn off.
    Sergeant:
  • 263 Answers
Check the sensors on either side of the door.
Also, see if there is a timer setting and if it's at max!
Posted on Aug 18, 2008
SOURCE:
My Crafstman garage opener is melting my light bulbs!
Rather than new bulbs I suggest you unplug the unit and use a small screwdriver to pull out on the center contact of the light socket.
Nov 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Light bulbs burn out constantly on Chamberlain garage door opener
Get an electrician to measure voltage where the light is plugged in. It sounds like you have too high a voltage.
Aug 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Light bulbs constantly burn out in Chamberlain Garage Door Opener
Unplug the unit from the power and take a screwdriver and pull out on the center contact of the socket.
Jul 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote will not work when the lights are on
Does unit work from wall button during the two minutes. I;d say this is certainly odd. Might need new board.
Apr 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Garage Door Opener
THE POWER SURGE PROBABLY FRIED THE TIMER CIRCUIT.
CAN YOU TURN OFF THE LIGHT FROM YOUR WALL CONTROL?
THE ONLY FIX I KNOW IS A WHOLE NEW CIRCUIT BOARD. - NOT CHEAP
HOPE THIS HELPS
Jul 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener light bulbs burning out
You can replace the socket itself. Unless there is extreme vibration this will be your best bet. If there is vibration then use some rubber washers to lessen this. You can get replacement parts at chamberlain.com. Thanks BB
Mar 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
Unplug the unit and look inside the socket. there is a copper lead you can bend up as it might not be getting a good contact. If that is not it you can start by replacing the socket itself from the manufacturer. If that does not do it then you will have to replace the logic board. Whether you reair or replace get a surge protector on this unit 900 joules or higher. Thanks BB
Feb 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
159 people viewed this question
Top Sears Building Materials Experts
Mike
Steve Allison
Steve Allison
Are you a Sears Building Material Expert? Answer questions, earn points and help others
